In ActionScript, Relevance Substitutions are delimited by { } symbols.
When you need a literal open curly bracket {, without beginning a Relevance Substitution, escape it by doubling it to {{
When you are inside a relevance Substitution, and need a literal } without ending the substitution, double it up as }}
Inside a substitution, the literal { does not need to be escaped; outside of a substitution, the literal } does not need to be escaped.
Here’s an example with both cases
//Escape the literal `}` in the GUID so it does not end the relevance substitution. Inside a substitution the `{` does not need to be escaped.
if {exists key "HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Microsoft\Windows\CurrentVersion\Uninstall\InstallShield_{B5BACF37-1A3C-4923-ADD7-5AEDA14740ED}}" of registry }
//Escape the literal `{` in the GUID so it does not begin a relevance substitution. Outside a substitution the `}` does not need to be escaped.
regkeydelete "[HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Microsoft\Windows\CurrentVersion\Uninstall\InstallShield_{{B5BACF37-1A3C-4923-ADD7-5AEDA14740ED}]"
See also the script task builder dashboard here:
