Web reports using Custom Analysis
I created an analysis to track if a system service is running or stopped on a set of servers. I want to create a web report that runs on a schedule to look at this analysis and triggers and email alert if it has changed. I am struggling to see how to incororate the analysis into the web report.
Any insight is appreciated!
-Josh
@JBianco, within WebReports and under the “Explore Data” then “Computers” navigation options you would simploy expand the “Edit Columns” option and then start typing the name of your analysis as shows in the screenshot below. In this example, the name of my analysis is IPSubnetInfo from my open source project for relay affiliation.
Once you’ve limited the columns to your analysis results, simply check the options you want displayed in your custom report. I hope this helps.
