Hey guys,
How would I go about defining specific exit codes as success criteria for a task?
For instance, for all our software distribution packages, we’d like the action to only show as completed if the exit code is 0 or 3010.
Thanks for your help,
Hey guys,
Hello!
One option we have is to make the relevance of the fixlet such that it is only not-relevant if the application is actually installed. Uninstall Keys are normally added at the very end of the installation and so using a registry check is often a great way to find out if something is installed. This will work much better than exit codes.
To answer your question:
You have a couple options – if you use “exit #” in an action but not on the last line of the action, the action will show as failed. You can do:
if {exit code of action != 0 and exit code of action != 3010}
exit {exit code of action}
endif
You can fail the action with continue if:
continue if {exit code of action = 0 or exit code of action != 3010}
Hi @strawgate
Where exactly in the action script would I have to insert these lines?
Thanks,
Raphael
You’d put them right after the place you ran the external process to check its return item. The action would then be able to fail if the process did not terminate with the right exit code.
That worked, thanks
We had to alter the action script mentioned above slightly
If you don’t use the action script as following it will stop at the first condition if it evaluates to false and not check any further
continue if {(exit code of action = 0) or (exit code of action = 3010)}
Thanks to @steini44
Sorry – i’ll edit my examples above. I misunderstood and thought we were failing on error code 0 and error code 3010!
Bill
You might also want to flag the action as pending restart in case of 3010…
continue if {exit code of action = 0 or exit code of action = 3010}
if {exit code of action = 3010}
action requires restart "reboot_for_my_package"
endif
That will leave the Action with the status “Pending Restart” instead of “Fixed” until the reboot occurs.
Hi Jason,
if {not exists keys whose (value “DisplayName” of it as string starts with “Microsoft Visual C++ 2015-2022 Redistributable (x64)” AND value “DisplayVersion” of it as string >= “11.12.14423.0”) of keys “HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall” of ( x64 registries; x32 registries )}
prefetch 20068efb77ea99b972ca4d0f87b93ec9fdcea7e4 sha1:20068efb77ea99b972ca4d0f87b93ec9fdcea7e4 size:25389860 http://bfroot.com:52311/Uploads/20068efb77ea99b972ca4d0f87b93ec9fdcea7e4/VC_redist.x64.exe.tmp sha256:a2908bb5a2d63eed3f99ef1cda3e771b484caa9da3dbfee8324685f8af6ad68d
extract 20068efb77ea99b972ca4d0f87b93ec9fdcea7e4
waithidden __Download\VC_redist.x64.exe /quiet /noreboot
endif
action requires restart “Microsoft Visual C++”
endif
The above action failes at the condition " if {exit code of action = 3010} " …
Please help me to change the logic to manage the 3010 code error
