Maybe you can provide us with more info so that we can try to help.
Is the format you described above 3 sections summarizing server/workstation/laptops?
It is not clear to me the format of the report.
Any definition on fully patched will be useful. For example, is a computer with one patch outstanding considered Not Compliant? What about if the patch is Medium or Low priority?
Have you looked at other reports already on the forum?
I required exactly same report for me but my requirements are less. i only require the report for desktops
any format as long as its showing the % in total .
This is only for Critical and important patches in Patch Release site.
any computer with more than 1 patch can be conciderd.
let me know what more information you need. i have tried downloading two different reports and run them but they dont provide this simple information.
@javed.tariq, have you seen this report?
If you add the appropriate filters - Device Type = Desktop, and also the patch sites, you should get the info needed.
