My below command keep failed in bigfix after i SD to selected client, is there anything wrong with my entire line?
regset64 “[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\Class{4d36e972-e325-11ce-bfc1-08002be10318}\0002]” “*EEE”=“0”
You need to escape the { symbol by replacing it with {{, else that is being interpreted as a Relevance substitution. See Tip: Escaping curly brackets for substitutions in ActionScript
Also, you don’t really need to use regset64 explicitly for HKLM\SYSTEM, unlike HKLM\Software, that is not branched differently for x32 or x64 so regset & regset64 would do the same exact job.
Thank you, it works.
