(imported topic written by PaulPhillabaum)
The wording of one action in task “BES Client Setting: Client UI Minimum Analysis Interval” contradicts itself. The task has three actions:
Click here to increase the Minimum Analysis Interval if you are not using the Offers feature. (Recommended)
Click here to increase the Minimum Analysis Interval if you are using the Offers feature. (Recommended)
Click here to set the Minimum Analysis Interval to the default value.
The action scripts set _BESClient_Report_MinimumAnalysisInterval to 300, 30, and default respectively. There is a comment in action 3, that the default for besclients > v7.2 .1.357 is 60. Hence, the second action will actually lower the interval from 60 to 30. For pre-7.2.1.357 clients, the second action will increase the interval from 5 to 30.
For anyone who is using offers, have you found a value higher than 60 that works well for you?
