Hi, I am using external repository to store some tools which I prefetch in actionscript.
But action is not able to cache tool exe from repository on IEM server. Error : The requested URL does not pass this deployment's download whitelist
After correcting typo error it started working.
Thanks for all help.
Few things I learned -
Regular expression is not necessary in DownloadWhitelist.txt . One can simply type link like - http://<server>.<domain>/.* to whitelist every path starting with http://<server>.<domain>/ 2.No need to escape special character . (dot)
You shouldn’t need to modify the download whitelist if you are just using a standard prefetch – only if you are doing dynamic downloads within your actionscript (which is fairly uncommon)
You can’t whitelist the Java downloads - Oracle does not make them available, so if you check the fixlets there is not actually a usable URL for the downloads.
That’s not a configuration issue on your part, it’s intentional aggravation invoked by Oracle.
Yes, see the description on the fixlet. You have to download the java installer manually and cache it on your server, but once that’s done you can deploy it to your clients with the fixlet.
