I can still browse to a PC, ping, but anything that copies does nothing…
Copy hostname for instance. The reg key list this as the action: Iignore the double\, copied from exported reg key)
“ShellCommandRelevance”="“C:\Program Files (x86)\BigFix Enterprise\BES Console\RunQuiet.exe sha1.exe -h " & name of current computer”
I tried to play with that in the fixlet debugger, “name of current computer” is no good in relevance, and “-h” in sha1.exe -h isn’t even supported in Dos… I’m experimenting but so far no good… How did this work before ? What am I missing ? I deleted the whole registry key and reinstalled right click tools to no avail…
Thank you… That’s exactly what I have, no quote at the end - from the official right click tools install from the console. No workie though, it doesn’t copy a thing, and other menus do work - just not the ones that copy things into memory. It used to work - I used it all the time, maybe something that broke when I reimaged to Win10 1809 or following a patch…
What I find interesting is the syntax because as I said “name of current computer” doesn’t fly in QNA (computer name does), nor does sha1.exe -h (bad switch) in DOS. I’m curious how that worked before.
‘name of current computer’ is a Session Relevance query, it won’t work in Client Relevance/Fixlet Debugger.
Session Relevance is a query that runs against the BigFix Database, (REST API, Web Reports, Console Dashboards)…in particular that one only works in the Console, and returns the name of the highlighted/selected computer
Thats odd, do you have the sha1.exe and runquiet in your install directory?
You could also try copying a specific property like this : "C:\Program Files (x86)\BigFix Enterprise\BES Console\RunQuiet.exe sha1.exe -h " & (value of property results whose (name of property of it = "property here" ) of current computer)
Ok, this same function using the same regedit entry works perfectly on another machine so there must be something fishy about this particular computer.
Jason this is just a right click “copies the PC name” - it’s from right click options, which I thought came from you guys, it’s installed from the console itself…
itsmpro92 and MMosley, Both runquiet and sha1 are in the location in question - I found out they get installed when yourun the right click tools fixlet, but -h is not a valid sha1 switch when tried in isolation… Yet this works on another PC I just built so I don’t know anymore… No worries… it’s got to be a pc specific issue
edit: I removed the console, delete the reg keys left behind, reinstalled the console and right click tools and it works again !!!
For others who are following this thread: right-click tools are an add-on provided by BigFix Labs. The tools are implemented by a custom task that you import into the Master Action Site or a custom site. It will target any computer running the BigFix Console. There is also a global property, which you may or may not need, to detect if Remote Desktop is running on Windows computers.
