When working with a BigFix support technician on the phone to troubleshoot an issue with a client not receiving a relevant action they had me create a custom task which had the following Action script.
Notify Client ForceRefresh
What is the difference between having a client run this action and just right clicking on the computer in the console and sending a refresh command? I understand when you send a refresh the BigFix server sends out a UDP packet to the endpoint notify the client to check back in with BigFix. Does runnting this action against an endpoint cause the client to do a more complete evaulation against any all Fixlets, Tasks, Baselines, Actions ect?
I did some testing on this one and you can validate for yourself with debug logging turned up. The notify client forcerefresh will trigger a complete evaluation of content for the site that it was in. And from what I’ve seen only that site.
-Gary
So if I’m experiencing a problem content in a site I should create a new task in the same site and deploy the action that lives in the site that is having issues?
Can you provide more details by what you call ‘problem content’?
My most common use of this is right after a major patching activity or application installs as most of my properties are set to only evaluate once a day or longer. After all of the changes are done we would include this step for the custom site that holds the analsyis that we use for auditing the results, and then we don’t have to wait a day or more for the reports to be valid.
