Monitor symbol and CPU Symbol
Hi, The monitor symbol represents that the device is a Desktop. The CPU symbol represents that the device a server. You will also get a symbol which will look like an laptop that will be laptop.
Regards,
Karthik
Hello Joby,
You might also take a look at the “Device Type” reserved property
Regards,
Vitaliy
Thanks Karthik, but in my Console everything is showing wrong…
VM is showing as a Desktop Icon
Desktop is showing as a CPU Icon
Laptop is showing as a Desktop or CPU icon…
Not in Correct Manner, is there any option where i can correct them against respective assets
Please see the following:
You can override the device type that is returned by creating/updating the following setting with the appropriate value:
_BESClient_DeviceTypeOverride
