BigFix SQL Named Instance Diagnostics Issues
Hello,
Does anyone have any experience deploying BigFix with a local SQL Server that has a named instance instead of the default instance?
We have deployed BigFix and everything appears to be working but we are receiving an error in the diagnostics tool that it is unable to verify that SQL Server is available over TCP/IP
Thanks!
This isn’t much help, as it is unanswered, but this looks like the same question: TCP/IP is enabled on SQL Server
Yeah – and TCP/IP is enabled under the network configuration of the SQL server so we’re wondering what effect this might have. It might be PMR time
