Something like this (I just took the one I used for my requirements and changed the computer name and property names so add/remove properties to meet your needs)
name of item 0 of it|"Computer Name missing"
, (if (size of item 1 of it = 1) then ((if it = "" then "No values" else it) of concatenation ";" of values of results (item 0 of it, elements of item 1 of it)) else (if (size of item 1 of it > 1) then (("Duplicates: " & concatenation "|" of ((name of it) & "=" & (id of it as string)) of elements of item 1 of it) as string) else ("Property does not exist")))
, (if (size of item 2 of it = 1) then ((if it = "" then "No values" else it) of concatenation ";" of values of results (item 0 of it, elements of item 2 of it)) else (if (size of item 2 of it > 1) then (("Duplicates: " & concatenation "|" of ((name of it) & "=" & (id of it as string)) of elements of item 2 of it) as string) else ("Property does not exist")))
, (if (size of item 3 of it = 1) then ((if it = "" then "No values" else it) of concatenation ";" of values of results (item 0 of it, elements of item 3 of it)) else (if (size of item 3 of it > 1) then (("Duplicates: " & concatenation "|" of ((name of it) & "=" & (id of it as string)) of elements of item 3 of it) as string) else ("Property does not exist")))
, (if (size of item 4 of it = 1) then ((if it = "" then "No values" else it) of concatenation ";" of values of results (item 0 of it, elements of item 4 of it)) else (if (size of item 4 of it > 1) then (("Duplicates: " & concatenation "|" of ((name of it) & "=" & (id of it as string)) of elements of item 4 of it) as string) else ("Property does not exist")))
, (if (size of item 5 of it = 1) then ((if it = "" then "No values" else it) of concatenation ";" of values of results (item 0 of it, elements of item 5 of it)) else (if (size of item 5 of it > 1) then (("Duplicates: " & concatenation "|" of ((name of it) & "=" & (id of it as string)) of elements of item 5 of it) as string) else ("Property does not exist")))
, (if (size of item 6 of it = 1) then ((if it = "" then "No values" else it) of concatenation ";" of values of results (item 0 of it, elements of item 6 of it)) else (if (size of item 6 of it > 1) then (("Duplicates: " & concatenation "|" of ((name of it) & "=" & (id of it as string)) of elements of item 6 of it) as string) else ("Property does not exist")))
, (if (size of item 7 of it = 1) then ((if it = "" then "No values" else it) of concatenation ";" of values of results (item 0 of it, elements of item 7 of it)) else (if (size of item 7 of it > 1) then (("Duplicates: " & concatenation "|" of ((name of it) & "=" & (id of it as string)) of elements of item 7 of it) as string) else ("Property does not exist")))
, (if (size of item 8 of it = 1) then ((if it = "" then "No values" else it) of concatenation ";" of values of results (item 0 of it, elements of item 8 of it)) else (if (size of item 8 of it > 1) then (("Duplicates: " & concatenation "|" of ((name of it) & "=" & (id of it as string)) of elements of item 8 of it) as string) else ("Property does not exist")))
, (if (size of item 9 of it = 1) then ((if it = "" then "No values" else it) of concatenation ";" of values of results (item 0 of it, elements of item 9 of it)) else (if (size of item 9 of it > 1) then (("Duplicates: " & concatenation "|" of ((name of it) & "=" & (id of it as string)) of elements of item 9 of it) as string) else ("Property does not exist")))
, (if (size of item 10 of it = 1) then ((if it = "" then "No values" else it) of concatenation ";" of values of results (item 0 of it, elements of item 10 of it)) else (if (size of item 10 of it > 1) then (("Duplicates: " & concatenation "|" of ((name of it) & "=" & (id of it as string)) of elements of item 10 of it) as string) else ("Property does not exist")))
, (if (size of item 11 of it = 1) then ((if it = "" then "No values" else it) of concatenation ";" of values of results (item 0 of it, elements of item 11 of it)) else (if (size of item 11 of it > 1) then (("Duplicates: " & concatenation "|" of ((name of it) & "=" & (id of it as string)) of elements of item 11 of it) as string) else ("Property does not exist")))
, (if (size of item 12 of it = 1) then ((if it = "" then "No values" else it) of concatenation ";" of values of results (item 0 of it, elements of item 12 of it)) else (if (size of item 12 of it > 1) then (("Duplicates: " & concatenation "|" of ((name of it) & "=" & (id of it as string)) of elements of item 12 of it) as string) else ("Property does not exist")))
, (if (size of item 13 of it = 1) then ((if it = "" then "No values" else it) of concatenation ";" of values of results (item 0 of it, elements of item 13 of it)) else (if (size of item 13 of it > 1) then (("Duplicates: " & concatenation "|" of ((name of it) & "=" & (id of it as string)) of elements of item 13 of it) as string) else ("Property does not exist")))
, (if (size of item 14 of it = 1) then ((if it = "" then "No values" else it) of concatenation ";" of values of results (item 0 of it, elements of item 14 of it)) else (if (size of item 14 of it > 1) then (("Duplicates: " & concatenation "|" of ((name of it) & "=" & (id of it as string)) of elements of item 14 of it) as string) else ("Property does not exist")))
, (if (size of item 15 of it = 1) then ((if it = "" then "No values" else ((((year of it as string & "/" & month of it as two digits & "/" & day_of_month of it as two digits) of date (local time zone) of it & " " & (two digit hour of it as string & ":" & two digit minute of it as string) of time (local time zone) of it)) of (it as time))) of concatenation ";" of values of results (item 0 of it, elements of item 15 of it)) else (if (size of item 15 of it > 1) then (("Duplicates: " & concatenation "|" of ((name of it) & "=" & (id of it as string)) of elements of item 15 of it) as string) else ("Property does not exist")))
of
elements of item 0 of it
,item 1 of it
,item 2 of it
,item 3 of it
,item 4 of it
,item 5 of it
,item 6 of it
,item 7 of it
,item 8 of it
,item 9 of it
,item 10 of it
,item 11 of it
,item 12 of it
,item 13 of it
,item 14 of it
,item 15 of it
of
set of BES computers whose (name of it as uppercase is "MYCOMPUTER")
, set of bes properties whose (name of it as lowercase = ("Property1") as lowercase)
, set of bes properties whose (name of it as lowercase = ("Property2") as lowercase)
, set of bes properties whose (name of it as lowercase = ("Property3") as lowercase)
, set of bes properties whose (name of it as lowercase = ("Property4") as lowercase)
, set of bes properties whose (name of it as lowercase = ("Property5") as lowercase)
, set of bes properties whose (name of it as lowercase = ("Property6") as lowercase)
, set of bes properties whose (name of it as lowercase = ("Property7") as lowercase)
, set of bes properties whose (name of it as lowercase = ("Property8") as lowercase)
, set of bes properties whose (name of it as lowercase = ("Property9") as lowercase)
, set of bes properties whose (name of it as lowercase = ("Property10") as lowercase)
, set of bes properties whose (name of it as lowercase = ("Property11") as lowercase)
, set of bes properties whose (name of it as lowercase = ("Property12") as lowercase)
, set of bes properties whose (name of it as lowercase = ("Property13") as lowercase)
, set of bes properties whose (name of it as lowercase = ("Property14") as lowercase)
, set of bes properties whose (name of it as lowercase = ("Property15") as lowercase)
