HI. I ran the server components updates on my Windows server which was running version 10.0.8 (and nothing else - other then the dedicated SQL Server).
After the restart of the server, BigFix console was not loading (reporting database connections issues).
I restored a backup of the VM (prior to upgrade), retried the updates and it failed once again.
I opened a ticket. They found that some setting disappeared from the registry (like ODBC connections). After that was recreated, Console can now open.
But:
- still can’t run the upgrade with success
- Web Reports now reports database connections issues
Support can’t fix the issue yet.
Anybody else experienced issues? Any solution?
