(imported topic written by Supanono91)
In the BES Client path i can found xlat files but there only , JAP, EN, CHS version , so i did translate into a FR, DE, AEU, and some others version.
Now how can deploy theses files on all computers ?
Best Regards
Hi Supanono,
That is very interesting that you figure it out and did the translation…
You can distribute the files using the software distribution wizard and then add a line to make sure to copy it to the right place…
Remember to make sure that is is UTF8 format.
system
3
(imported comment written by robmuh91)
Are any of the xlat translation functions available through relevance? I could find none.
BenKus
4
Hi robmuh,
I am not sure what you mean… can you give some more background on your request?
