Watch out for a couple of gotchas in your relevance. You’re not filtering to a particular display adapter type (so you’ll hit both Nvidia and ATI cards if their driver version is not exactly 10.18.14), and you’re also not looking for “this version or higher” so a system with 11.19.15 would also be relevant.
For the purpose of this post I’m assuming NVidia, but the same applies to all PnP drivers, just swap out the ProviderName, ClassGUID, and DriverVersion values as needed.
I handle my driver relevance a little bit differently. Knowing that the loaded drivers are shown in HKLM\system\CurrentControlSet\Control\Class, and the Display ClassGUID is {4d36e968-e325-11ce-bfc1-08002be10318}, my Relevance would look like
exists keys whose (value "ProviderName" of it as string = "NVidia" and value "DriverVersion" of it as string as version < version "10.18.14") of keys "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4d36e968-e325-11ce-bfc1-08002be10318}" of registry
To take it a leap forward, and account for the fact that NVidia drops support for older devices in their newer drivers, I want to get a list of PnP IDs for devices that are still present in the new driver. To do that I extract their driver into a directory and read the PnP IDs from the driver:
To get the list of PnP IDs for a given set of driver INF files:
concatenation ";" of ("%22pci\" & it & "%22") of unique values of (following texts of firsts "PCI\" of lines of find files "*.inf" of folder "c:\temp\Display.Driver" as trimmed string as lowercase)
I paste that result into a Relevance statement that I have pre-canned for each class type and provider - the template statement looks like this. In this statement, we need to replace the ClassGUID values (to switch between Video/Network/etc.), ProviderName, DriverVersion, and the list of PnP IDs (generated in the previous statement)
exists (keys of keys of key "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\PCI" of native registry) whose ( /* if class is defined then class matches expectation (in this case, "Video"); if no class is listed then its an unknown device and may still be relevant */(if exists (value "ClassGUID" of it) then (/* SUBST CLASS HERE */ value "ClassGUID" of it as string = "{4d36e968-e325-11ce-bfc1-08002be10318}") else true) AND /* if there is no "Driver" key then true, else check the driver present in the "Driver" key */ (if not exists value "Driver" of it then true else (exists (it, /* SUBST CLASS HERE */ keys of key "{4d36e968-e325-11ce-bfc1-08002be10318}" of key "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class" of native registry) whose (pathname of item 1 of it as lowercase ends with value "Driver" of item 0 of it as string as lowercase AND ( /* wrong Provider */ not exists (value "ProviderName" of item 1 of it) whose (it = "NVIDIA") or ( /* version too low */ not exists (value "DriverVersion" of item 1 of it) whose (it as string as version >= version "22.21.13.8569")))) )) AND ( /* exists a hardware ID matching our expected list from INF*/ exists (substrings separated by "%00" of ((values "CompatibleIDs" of it; values "HardwareID" of it) as string as lowercase as trimmed string)) whose (it != "" and it is contained by set of ("INSERT_PNP_IDS_HERE"))) )
This statement looks for PnP IDs matching the NVidia drives for whatever driver version, found in ENUM\PCI, that either have no driver loaded, have a driver loaded that’s not from NVidia (like default MS SVGA), or have the NVidia driver with a lower version than expected.
In the end, here’s my statement for the relevance I’m using to detect NVidia Quadro 385.69 (driver version 22.21.13.8569). It’s ugly to read, but since it’s mostly generated I don’t mind:
exists (keys of keys of key "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\PCI" of native registry) whose ( /* if class is defined then class matches expectation (in this case, "Video"); if no class is listed then its an unknown device and may still be relevant */(if exists (value "ClassGUID" of it) then (/* SUBST CLASS HERE */ value "ClassGUID" of it as string = "{4d36e968-e325-11ce-bfc1-08002be10318}") else true) AND /* if there is no "Driver" key then true, else check the driver present in the "Driver" key */ (if not exists value "Driver" of it then true else (exists (it, /* SUBST CLASS HERE */ keys of key "{4d36e968-e325-11ce-bfc1-08002be10318}" of key "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class" of native registry) whose (pathname of item 1 of it as lowercase ends with value "Driver" of item 0 of it as string as lowercase AND ( /* wrong Provider */ not exists (value "ProviderName" of item 1 of it) whose (it = "NVIDIA") or ( /* version too low */ not exists (value "DriverVersion" of item 1 of it) whose (it as string as version >= version "22.21.13.8569")))) )) AND ( /* exists a hardware ID matching our expected list from INF*/ exists (substrings separated by "%00" of ((values "CompatibleIDs" of it; values "HardwareID" of it) as string as lowercase as trimmed string)) whose (it != "" and it is contained by set of ("pci\ven_10de&dev_06d1";"pci\ven_10de&dev_06d1&subsys_077110de";"pci\ven_10de&dev_06d1&subsys_077210de";"pci\ven_10de&dev_06d2";"pci\ven_10de&dev_06d2&subsys_077410de";"pci\ven_10de&dev_06d2&subsys_083010de";"pci\ven_10de&dev_06d2&subsys_084210de";"pci\ven_10de&dev_06d2&subsys_088f10de";"pci\ven_10de&dev_06d2&subsys_090810de";"pci\ven_10de&dev_06da&subsys_081a1028";"pci\ven_10de&dev_06da&subsys_1520103c";"pci\ven_10de&dev_06de";"pci\ven_10de&dev_06de&subsys_077310de";"pci\ven_10de&dev_06de&subsys_082f10de";"pci\ven_10de&dev_06de&subsys_084010de";"pci\ven_10de&dev_06de&subsys_084210de";"pci\ven_10de&dev_06de&subsys_084610de";"pci\ven_10de&dev_06de&subsys_086610de";"pci\ven_10de&dev_06de&subsys_090710de";"pci\ven_10de&dev_06de&subsys_091e10de";"pci\ven_10de&dev_06df";"pci\ven_10de&dev_06df&subsys_084d10de";"pci\ven_10de&dev_06df&subsys_087f10de";"pci\ven_10de&dev_0dda&subsys_04a31028";"pci\ven_10de&dev_0dda&subsys_14a31028";"pci\ven_10de&dev_0dda&subsys_1631103c";"pci\ven_10de&dev_0dda&subsys_21cf17aa";"pci\ven_10de&dev_0dda&subsys_21d117aa";"pci\ven_10de&dev_0def&subsys_21f317aa";"pci\ven_10de&dev_0def&subsys_21f417aa";"pci\ven_10de&dev_0def&subsys_21f517aa";"pci\ven_10de&dev_0def&subsys_21f617aa";"pci\ven_10de&dev_0def&subsys_21f817aa";"pci\ven_10de&dev_0def&subsys_500517aa";"pci\ven_10de&dev_0dfc&subsys_05341028";"pci\ven_10de&dev_0dfc&subsys_05351028";"pci\ven_10de&dev_0dfc&subsys_15341028";"pci\ven_10de&dev_0dfc&subsys_15351028";"pci\ven_10de&dev_0ff3";"pci\ven_10de&dev_0ff6&subsys_05cc1028";"pci\ven_10de&dev_0ff6&subsys_060d1028";"pci\ven_10de&dev_0ff6&subsys_15cc1028";"pci\ven_10de&dev_0ff6&subsys_17ee10cf";"pci\ven_10de&dev_0ff6&subsys_1909103c";"pci\ven_10de&dev_0ff6&subsys_190a103c";"pci\ven_10de&dev_0ff6&subsys_197a103c";"pci\ven_10de&dev_0ff6&subsys_197b103c";"pci\ven_10de&dev_0ff6&subsys_221017aa";"pci\ven_10de&dev_0ff6&subsys_221117aa";"pci\ven_10de&dev_0ff6&subsys_221a17aa";"pci\ven_10de&dev_0ff6&subsys_221e17aa";"pci\ven_10de&dev_0ff6&subsys_2253103c";"pci\ven_10de&dev_0ff6&subsys_2254103c";"pci\ven_10de&dev_0ff6&subsys_2255103c";"pci\ven_10de&dev_0ff6&subsys_2256103c";"pci\ven_10de&dev_0ff6&subsys_22fa1043";"pci\ven_10de&dev_0ff6&subsys_51061558";"pci\ven_10de&dev_0ff6&subsys_52811558";"pci\ven_10de&dev_0ff6&subsys_71041558";"pci\ven_10de&dev_0ff6&subsys_74811558";"pci\ven_10de&dev_0ff6&subsys_75001558";"pci\ven_10de&dev_0ff6&subsys_77001558";"pci\ven_10de&dev_0ff6&subsys_8104103c";"pci\ven_10de&dev_0ff8&subsys_176a10cf";"pci\ven_10de&dev_0ff9";"pci\ven_10de&dev_0ffa";"pci\ven_10de&dev_0ffb&subsys_053e1028";"pci\ven_10de&dev_0ffb&subsys_10db1462";"pci\ven_10de&dev_0ffb&subsys_153e1028";"pci\ven_10de&dev_0ffb&subsys_175e10cf";"pci\ven_10de&dev_0ffb&subsys_175f10cf";"pci\ven_10de&dev_0ffb&subsys_176b103c";"pci\ven_10de&dev_0ffb&subsys_21f517aa";"pci\ven_10de&dev_0ffb&subsys_21f617aa";"pci\ven_10de&dev_0ffc&subsys_053e1028";"pci\ven_10de&dev_0ffc&subsys_10db1462";"pci\ven_10de&dev_0ffc&subsys_153e1028";"pci\ven_10de&dev_0ffc&subsys_175e10cf";"pci\ven_10de&dev_0ffc&subsys_176b103c";"pci\ven_10de&dev_0ffc&subsys_21f517aa";"pci\ven_10de&dev_0ffc&subsys_21f617aa";"pci\ven_10de&dev_0ffc&subsys_51061558";"pci\ven_10de&dev_0ffc&subsys_71041558";"pci\ven_10de&dev_0ffd";"pci\ven_10de&dev_0ffe";"pci\ven_10de&dev_0fff";"pci\ven_10de&dev_0fff&subsys_094a10de";"pci\ven_10de&dev_1021";"pci\ven_10de&dev_1022";"pci\ven_10de&dev_1023";"pci\ven_10de&dev_1024";"pci\ven_10de&dev_1026";"pci\ven_10de&dev_1027";"pci\ven_10de&dev_1028";"pci\ven_10de&dev_1029";"pci\ven_10de&dev_102a";"pci\ven_10de&dev_102d";"pci\ven_10de&dev_103a";"pci\ven_10de&dev_103c";"pci\ven_10de&dev_1056&subsys_04931028";"pci\ven_10de&dev_1056&subsys_04941028";"pci\ven_10de&dev_1056&subsys_04e41028";"pci\ven_10de&dev_1056&subsys_14931028";"pci\ven_10de&dev_1056&subsys_14941028";"pci\ven_10de&dev_1056&subsys_14e41028";"pci\ven_10de&dev_1056&subsys_163610cf";"pci\ven_10de&dev_1056&subsys_21d217aa";"pci\ven_10de&dev_1056&subsys_21d317aa";"pci\ven_10de&dev_1057&subsys_21ce17aa";"pci\ven_10de&dev_1057&subsys_21cf17aa";"pci\ven_10de&dev_1057&subsys_21d017aa";"pci\ven_10de&dev_1057&subsys_21d117aa";"pci\ven_10de&dev_1057&subsys_c0a6144d";"pci\ven_10de&dev_1057&subsys_c0af144d";"pci\ven_10de&dev_1057&subsys_c0b0144d";"pci\ven_10de&dev_107c";"pci\ven_10de&dev_107c&subsys_102f10de";"pci\ven_10de&dev_107d";"pci\ven_10de&dev_1091";"pci\ven_10de&dev_1091&subsys_088710de";"pci\ven_10de&dev_1091&subsys_088e10de";"pci\ven_10de&dev_1091&subsys_089110de";"pci\ven_10de&dev_1094";"pci\ven_10de&dev_1094&subsys_088810de";"pci\ven_10de&dev_1096";"pci\ven_10de&dev_1096&subsys_091010de";"pci\ven_10de&dev_1096&subsys_091110de";"pci\ven_10de&dev_1140&subsys_220017aa";"pci\ven_10de&dev_118f";"pci\ven_10de&dev_1194";"pci\ven_10de&dev_11b4";"pci\ven_10de&dev_11b6";"pci\ven_10de&dev_11b6&subsys_05cd1028";"pci\ven_10de&dev_11b6&subsys_10fc1462";"pci\ven_10de&dev_11b6&subsys_10fd1462";"pci\ven_10de&dev_11b6&subsys_11521462";"pci\ven_10de&dev_11b6&subsys_118c1462";"pci\ven_10de&dev_11b6&subsys_15cd1028";"pci\ven_10de&dev_11b6&subsys_190a103c";"pci\ven_10de&dev_11b6&subsys_197a103c";"pci\ven_10de&dev_11b6&subsys_2255103c";"pci\ven_10de&dev_11b6&subsys_2256103c";"pci\ven_10de&dev_11b6&subsys_51061558";"pci\ven_10de&dev_11b6&subsys_52811558";"pci\ven_10de&dev_11b6&subsys_71041558";"pci\ven_10de&dev_11b6&subsys_74811558";"pci\ven_10de&dev_11b6&subsys_75001558";"pci\ven_10de&dev_11b6&subsys_77001558";"pci\ven_10de&dev_11b7";"pci\ven_10de&dev_11b7&subsys_05cd1028";"pci\ven_10de&dev_11b7&subsys_11001462";"pci\ven_10de&dev_11b7&subsys_11531462";"pci\ven_10de&dev_11b7&subsys_118d1462";"pci\ven_10de&dev_11b7&subsys_15cd1028";"pci\ven_10de&dev_11b7&subsys_190a103c";"pci\ven_10de&dev_11b7&subsys_197a103c";"pci\ven_10de&dev_11b7&subsys_2255103c";"pci\ven_10de&dev_11b7&subsys_2256103c";"pci\ven_10de&dev_11b8&subsys_02701558";"pci\ven_10de&dev_11b8&subsys_03761558";"pci\ven_10de&dev_11b8&subsys_05cd1028";"pci\ven_10de&dev_11b8&subsys_15cd1028";"pci\ven_10de&dev_11b8&subsys_190a103c";"pci\ven_10de&dev_11b8&subsys_197a103c";"pci\ven_10de&dev_11b8&subsys_2255103c";"pci\ven_10de&dev_11b8&subsys_2256103c";"pci\ven_10de&dev_11b8&subsys_75001558";"pci\ven_10de&dev_11b8&subsys_77001558";"pci\ven_10de&dev_11ba";"pci\ven_10de&dev_11bc";"pci\ven_10de&dev_11bc&subsys_02701558";"pci\ven_10de&dev_11bc&subsys_03711558";"pci\ven_10de&dev_11bc&subsys_03761558";"pci\ven_10de&dev_11bc&subsys_053f1028";"pci\ven_10de&dev_11bc&subsys_153f1028";"pci\ven_10de&dev_11bc&subsys_176210cf";"pci\ven_10de&dev_11bc&subsys_176c103c";"pci\ven_10de&dev_11bd";"pci\ven_10de&dev_11bd&subsys_053f1028";"pci\ven_10de&dev_11bd&subsys_10db1462";"pci\ven_10de&dev_11bd&subsys_153f1028";"pci\ven_10de&dev_11bd&subsys_176110cf";"pci\ven_10de&dev_11bd&subsys_176c103c";"pci\ven_10de&dev_11be";"pci\ven_10de&dev_11be&subsys_053f1028";"pci\ven_10de&dev_11be&subsys_10db1462";"pci\ven_10de&dev_11be&subsys_10eb1462";"pci\ven_10de&dev_11be&subsys_153f1028";"pci\ven_10de&dev_11be&subsys_176010cf";"pci\ven_10de&dev_11be&subsys_176c103c";"pci\ven_10de&dev_11be&subsys_51051558";"pci\ven_10de&dev_11be&subsys_51061558";"pci\ven_10de&dev_11be&subsys_71021558";"pci\ven_10de&dev_11be&subsys_71041558";"pci\ven_10de&dev_11fa";"pci\ven_10de&dev_11fc";"pci\ven_10de&dev_11fc&subsys_00011179";"pci\ven_10de&dev_11fc&subsys_05cc1028";"pci\ven_10de&dev_11fc&subsys_10fb1462";"pci\ven_10de&dev_11fc&subsys_111d1462";"pci\ven_10de&dev_11fc&subsys_111e1462";"pci\ven_10de&dev_11fc&subsys_15cc1028";"pci\ven_10de&dev_11fc&subsys_1708172f";"pci\ven_10de&dev_11fc&subsys_17ef10cf";"pci\ven_10de&dev_11fc&subsys_1909103c";"pci\ven_10de&dev_11fc&subsys_197b103c";"pci\ven_10de&dev_11fc&subsys_221017aa";"pci\ven_10de&dev_11fc&subsys_221117aa";"pci\ven_10de&dev_11fc&subsys_221a17aa";"pci\ven_10de&dev_11fc&subsys_221e17aa";"pci\ven_10de&dev_11fc&subsys_2253103c";"pci\ven_10de&dev_11fc&subsys_2254103c";"pci\ven_10de&dev_12b9";"pci\ven_10de&dev_12b9&subsys_1909103c";"pci\ven_10de&dev_12b9&subsys_190a103c";"pci\ven_10de&dev_12b9&subsys_197a103c";"pci\ven_10de&dev_12b9&subsys_197b103c";"pci\ven_10de&dev_12b9&subsys_2253103c";"pci\ven_10de&dev_12b9&subsys_2254103c";"pci\ven_10de&dev_12ba&subsys_17ed10cf";"pci\ven_10de&dev_137a&subsys_222517aa";"pci\ven_10de&dev_137a&subsys_223217aa";"pci\ven_10de&dev_137a&subsys_505a17aa";"pci\ven_10de&dev_137b&subsys_224817aa";"pci\ven_10de&dev_13b0&subsys_06d91028";"pci\ven_10de&dev_13b0&subsys_116b1462";"pci\ven_10de&dev_13b0&subsys_116c1462";"pci\ven_10de&dev_13b0&subsys_11761462";"pci\ven_10de&dev_13b0&subsys_16d91028";"pci\ven_10de&dev_13b0&subsys_194b10cf";"pci\ven_10de&dev_13b0&subsys_194c10cf";"pci\ven_10de&dev_13b0&subsys_222e17aa";"pci\ven_10de&dev_13b0&subsys_223017aa";"pci\ven_10de&dev_13b0&subsys_80d5103c";"pci\ven_10de&dev_13b0&subsys_80d6103c";"pci\ven_10de&dev_13b0&subsys_8109103c";"pci\ven_10de&dev_13b0&subsys_810a103c";"pci\ven_10de&dev_13b1&subsys_01cf1b0a";"pci\ven_10de&dev_13b1&subsys_06d91028";"pci\ven_10de&dev_13b1&subsys_06e51028";"pci\ven_10de&dev_13b1&subsys_116b1462";"pci\ven_10de&dev_13b1&subsys_116c1462";"pci\ven_10de&dev_13b1&subsys_11771462";"pci\ven_10de&dev_13b1&subsys_16d91028";"pci\ven_10de&dev_13b1&subsys_194d10cf";"pci\ven_10de&dev_13b1&subsys_194e10cf";"pci\ven_10de&dev_13b1&subsys_222e17aa";"pci\ven_10de&dev_13b1&subsys_223017aa";"pci\ven_10de&dev_13b1&subsys_75001558";"pci\ven_10de&dev_13b1&subsys_75021558";"pci\ven_10de&dev_13b1&subsys_77001558";"pci\ven_10de&dev_13b1&subsys_77021558";"pci\ven_10de&dev_13b1&subsys_80d4103c";"pci\ven_10de&dev_13b1&subsys_80d5103c";"pci\ven_10de&dev_13b1&subsys_80d6103c";"pci\ven_10de&dev_13b1&subsys_8108103c";"pci\ven_10de&dev_13b1&subsys_8109103c";"pci\ven_10de&dev_13b1&subsys_810a103c";"pci\ven_10de&dev_13b2&subsys_01cf1b0a";"pci\ven_10de&dev_13b2&subsys_116b1462";"pci\ven_10de&dev_13b2&subsys_116c1462";"pci\ven_10de&dev_13b2&subsys_194f10cf";"pci\ven_10de&dev_13b2&subsys_195010cf";"pci\ven_10de&dev_13b2&subsys_222d17aa";"pci\ven_10de&dev_13b2&subsys_222f17aa";"pci\ven_10de&dev_13b2&subsys_80d5103c";"pci\ven_10de&dev_13b2&subsys_810a103c";"pci\ven_10de&dev_13b3&subsys_05cd1028";"pci\ven_10de&dev_13b3&subsys_11031462";"pci\ven_10de&dev_13b3&subsys_113e1462";"pci\ven_10de&dev_13b3&subsys_15cd1028";"pci\ven_10de&dev_13b3&subsys_2255103c";"pci\ven_10de&dev_13b3&subsys_2256103c";"pci\ven_10de&dev_13b4";"pci\ven_10de&dev_13b4&subsys_07a91028";"pci\ven_10de&dev_13b4&subsys_196610cf";"pci\ven_10de&dev_13b4&subsys_196910cf";"pci\ven_10de&dev_13b4&subsys_224c17aa";"pci\ven_10de&dev_13b4&subsys_225017aa";"pci\ven_10de&dev_13b4&subsys_824c103c";"pci\ven_10de&dev_13b4&subsys_824d103c";"pci\ven_10de&dev_13b4&subsys_8275103c";"pci\ven_10de&dev_13b4&subsys_8277103c";"pci\ven_10de&dev_13b6";"pci\ven_10de&dev_13b6&subsys_07b01028";"pci\ven_10de&dev_13b6&subsys_07b11028";"pci\ven_10de&dev_13b6&subsys_07bf1028";"pci\ven_10de&dev_13b6&subsys_17b01028";"pci\ven_10de&dev_13b6&subsys_17b11028";"pci\ven_10de&dev_13b6&subsys_196710cf";"pci\ven_10de&dev_13b6&subsys_196a10cf";"pci\ven_10de&dev_13b6&subsys_224d17aa";"pci\ven_10de&dev_13b6&subsys_225117aa";"pci\ven_10de&dev_13b6&subsys_826b103c";"pci\ven_10de&dev_13b6&subsys_826d103c";"pci\ven_10de&dev_13b6&subsys_8270103c";"pci\ven_10de&dev_13b6&subsys_8272103c";"pci\ven_10de&dev_13b6&subsys_8275103c";"pci\ven_10de&dev_13b6&subsys_8277103c";"pci\ven_10de&dev_13b9";"pci\ven_10de&dev_13ba";"pci\ven_10de&dev_13bb";"pci\ven_10de&dev_13bc";"pci\ven_10de&dev_13f0";"pci\ven_10de&dev_13f1";"pci\ven_10de&dev_13f2&subsys_113a10de";"pci\ven_10de&dev_13f2&subsys_115e10de";"pci\ven_10de&dev_13f2&subsys_115f10de";"pci\ven_10de&dev_13f3&subsys_114310de";"pci\ven_10de&dev_13f8&subsys_06da1028";"pci\ven_10de&dev_13f8&subsys_11791462";"pci\ven_10de&dev_13f8&subsys_11dd10de";"pci\ven_10de&dev_13f8&subsys_11f51462";"pci\ven_10de&dev_13f8&subsys_16da1028";"pci\ven_10de&dev_13f8&subsys_222d17aa";"pci\ven_10de&dev_13f8&subsys_222f17aa";"pci\ven_10de&dev_13f8&subsys_75001558";"pci\ven_10de&dev_13f8&subsys_75021558";"pci\ven_10de&dev_13f8&subsys_77001558";"pci\ven_10de&dev_13f8&subsys_77021558";"pci\ven_10de&dev_13f8&subsys_80d6103c";"pci\ven_10de&dev_13f8&subsys_8109103c";"pci\ven_10de&dev_13f9&subsys_06da1028";"pci\ven_10de&dev_13f9&subsys_11781462";"pci\ven_10de&dev_13f9&subsys_11961462";"pci\ven_10de&dev_13f9&subsys_16da1028";"pci\ven_10de&dev_13f9&subsys_222d17aa";"pci\ven_10de&dev_13f9&subsys_222f17aa";"pci\ven_10de&dev_13f9&subsys_80d6103c";"pci\ven_10de&dev_13f9&subsys_8109103c";"pci\ven_10de&dev_13fa&subsys_06da1028";"pci\ven_10de&dev_13fa&subsys_11751462";"pci\ven_10de&dev_13fa&subsys_11951462";"pci\ven_10de&dev_13fa&subsys_11c910de";"pci\ven_10de&dev_13fa&subsys_16da1028";"pci\ven_10de&dev_13fa&subsys_222d17aa";"pci\ven_10de&dev_13fa&subsys_222f17aa";"pci\ven_10de&dev_13fa&subsys_75001558";"pci\ven_10de&dev_13fa&subsys_75021558";"pci\ven_10de&dev_13fa&subsys_77001558";"pci\ven_10de&dev_13fa&subsys_77021558";"pci\ven_10de&dev_13fa&subsys_80d6103c";"pci\ven_10de&dev_13fa&subsys_8109103c";"pci\ven_10de&dev_13fb&subsys_11b01462";"pci\ven_10de&dev_1430";"pci\ven_10de&dev_1431&subsys_119310de";"pci\ven_10de&dev_1436";"pci\ven_10de&dev_1436&subsys_07b01028";"pci\ven_10de&dev_1436&subsys_115a1462";"pci\ven_10de&dev_1436&subsys_115b1462";"pci\ven_10de&dev_1436&subsys_116b1462";"pci\ven_10de&dev_1436&subsys_17b01028";"pci\ven_10de&dev_1436&subsys_196810cf";"pci\ven_10de&dev_1436&subsys_196b10cf";"pci\ven_10de&dev_1436&subsys_224d17aa";"pci\ven_10de&dev_1436&subsys_225117aa";"pci\ven_10de&dev_1436&subsys_8270103c";"pci\ven_10de&dev_1436&subsys_8272103c";"pci\ven_10de&dev_1436&subsys_8275103c";"pci\ven_10de&dev_1436&subsys_8277103c";"pci\ven_10de&dev_15f0";"pci\ven_10de&dev_15f7&subsys_11da10de";"pci\ven_10de&dev_15f8&subsys_118f10de";"pci\ven_10de&dev_15f9&subsys_116b10de";"pci\ven_10de&dev_17f0";"pci\ven_10de&dev_17f1";"pci\ven_10de&dev_17fd&subsys_117110de";"pci\ven_10de&dev_17fd&subsys_117310de";"pci\ven_10de&dev_1b30";"pci\ven_10de&dev_1b38&subsys_11d910de";"pci\ven_10de&dev_1bb0";"pci\ven_10de&dev_1bb1";"pci\ven_10de&dev_1bb3&subsys_11d810de";"pci\ven_10de&dev_1bb3&subsys_11e010de";"pci\ven_10de&dev_1bb4&subsys_11c610de";"pci\ven_10de&dev_1bb6&subsys_07b11028";"pci\ven_10de&dev_1bb6&subsys_11b410de";"pci\ven_10de&dev_1bb6&subsys_11f11462";"pci\ven_10de&dev_1bb6&subsys_17b11028";"pci\ven_10de&dev_1bb6&subsys_197010cf";"pci\ven_10de&dev_1bb6&subsys_197310cf";"pci\ven_10de&dev_1bb6&subsys_224c17aa";"pci\ven_10de&dev_1bb6&subsys_225017aa";"pci\ven_10de&dev_1bb6&subsys_8270103c";"pci\ven_10de&dev_1bb6&subsys_8272103c";"pci\ven_10de&dev_1bb7&subsys_07b11028";"pci\ven_10de&dev_1bb7&subsys_11e91462";"pci\ven_10de&dev_1bb7&subsys_17b11028";"pci\ven_10de&dev_1bb7&subsys_197110cf";"pci\ven_10de&dev_1bb7&subsys_197410cf";"pci\ven_10de&dev_1bb7&subsys_224c17aa";"pci\ven_10de&dev_1bb7&subsys_225017aa";"pci\ven_10de&dev_1bb7&subsys_8270103c";"pci\ven_10de&dev_1bb7&subsys_8272103c";"pci\ven_10de&dev_1bb7&subsys_95011558";"pci\ven_10de&dev_1bb8&subsys_07b11028";"pci\ven_10de&dev_1bb8&subsys_11ad1462";"pci\ven_10de&dev_1bb8&subsys_11b410de";"pci\ven_10de&dev_1bb8&subsys_17b11028";"pci\ven_10de&dev_1bb8&subsys_197210cf";"pci\ven_10de&dev_1bb8&subsys_197510cf";"pci\ven_10de&dev_1bb8&subsys_224c17aa";"pci\ven_10de&dev_1bb8&subsys_225017aa";"pci\ven_10de&dev_1bb8&subsys_8270103c";"pci\ven_10de&dev_1bb8&subsys_8272103c";"pci\ven_10de&dev_1bb8&subsys_95011558";"pci\ven_10de&dev_1c30";"pci\ven_10de&dev_1cb1";"pci\ven_10de&dev_1cb2";"pci\ven_10de&dev_1cb3"))) )
As ugly as it looks, it still evaluates quickly enough
A: False
T: 13.022 ms
I: singular boolean
edit I was about to warn that WMI calls are expensive, and then I saw you posted your evaluation time
A: False
T: 3215.827 ms
3215.827 ms in the Fixlet Debugger is going to take a lot longer in the real client with CPU throttling enabled, so watch out for performance impacts before you use this in a lot of Fixlet relevance. The WMI queries are better suited to Analysis properties where you can change the ‘evaluate every X minutes’ value so you’re not constantly hitting WMI.
