So my question is… will there ever be a data destroy option for the device…for example, a lost device gets sent a management command which completely erases the device? Or am I missing something here?
iOS doesn’t have SD Cards, but there is a supported Android command:
wipe externalStorage
This will trigger built-in Android functionality to wipe the external storage on Android devices… but the issue is that this is not supported on all Android versions… If you are interested in the details, the API docs from Google say (
int WIPE_EXTERNAL_STORAGE Flag for wipeData(int): also erase the device’s external storage.
… But the more info for the command tells us not to pass in the command that wipes the storage card… So we had implemented the feature, but since Google seems to be unsure what we should do (and they have changed their docs), we included the command but haven’t yet put it into Fixlet form…
I think what we can do is just build our own command to wipe the external storage (through normal file deleting techniques rather than through special Android supported calls)… I will let you know more info soon…
