Does anyone have any idea why this wouldn’t work?
When ran manually it creates the log file like I’ve asked it to but when ran from the fixlet it’s like the PS is never ran as the log file never gets created.
waithidden {pathname of file ((it as string) of value "Path" of key "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\PowerShell\1\ShellIds\Microsoft.PowerShell" of native registry) } -ExecutionPolicy Bypass -File "{pathname of find file "*.ps1" of folder "c:\temp\mdfi"}" > "c:\temp\mdfi\install.log"
The log file shows:
Command started - waithidden C:\Windows\System32\WindowsPowerShell\v1.0\powershell.exe -File "c:\temp\mdfi\file.ps1" > "c:\temp\mdfi\install.log" (action:541144103)
At 15:32:17 +0000 -
Report posted successfully
At 15:32:18 +0000 - actionsite (http://bfserver.com:52311/cgi-bin/bfgather.exe/actionsite)
Command succeeded (Exit Code=0) waithidden C:\Windows\System32\WindowsPowerShell\v1.0\powershell.exe -File "c:\temp\mdfi\file.ps1" > "c:\temp\mdfi\install.log" (action:541144103)
