(imported topic written by RobertKurt)
Does anyone know a good source of fields for computer, computer group, user, and more that would make it simpler to create custom reports in Web Reports?
Thanks!
Robert Kurtinaitis
Thanks!
Robert Kurtinaitis
(imported comment written by gearoid)
Garret
(imported comment written by Tim.Rice)
You are going to be using “Session Relevance” when using the API’s … These links might be of additional use …
http://support.bigfix.com/fixlet/documents/Session%20Inspectors%2081_110719.pdf
Also, from the Session Relevance Tester, try the following queries … relevance language is usually considered “self documenting”.
properties
and
properties whose (it as string as lowercase contains “fixlet”)
