What tools do you find useful to help create Bigfix content? ( Fixlets, Tasks, Analysis, etc… )
I’ve found both ResEdit & EXIFtool to be useful to help figure out what packaging tools were used to create the particular software installer I’m trying to automate through BigFix. See this post:
I have also used 7zip to extract the contents of many installers to get at the files used during installation. I have used “Universal Extractor” for installers that 7zip fails to extract.
I know the products you listed above. I use them, too.
I also use Advanced Installer to create MSI packages. The Free Edtion allows enough things to do. If you want dig deeper you have to buy a higher edition depending on your needs. The tool is easy to handle. I have used it for serveral thinks (installation Fonts for example).
Not so much a tool, but a site. I have used http://www.itninja.com/
(used to be appdeploy.com) as it usually has some really good tips for those difficult programs.
