Hi All,
Can anyone explain me what is PVU and RVU in SUA and how exactly to use this two value in SUA.
Thanks in advance
Hi All,
Thanks in advance
The short answer: ¯\_(ツ)_/¯
They are 2 different was to calculate license usage of IBM software for servers. One is better in terms of pricing if your licensed software is running on VMs, while the other is better if primarily run on physical hardware.
I don’t know much beyond that, and I find it confusing. In my experience most people from IBM don’t understand it either.
oh okay…Thanks for your short answer
But seriously…I’m confused too
and don’t know really how to work with PVU and RVU value in SUA…
You might contact your Account Rep for an explanation (if they can provide one). If they can, please post it back here!
Check out the following links, they should make the concept of PVU and RVU clearer:
PVU licenses
RVU licenses
There is also a nice infographic that explains the idea of PVU licensing: link
I hope it helps,
Agnieszka
Thanks A lot…link is very helpful in understanding the concept of RVU and PVU
