What is MEF extraction and how can we use it big fix
Can you provide us a little more detail or context?
for complaince and server management
we need to configure it
there is one crawler configuration
That’s an Internal GTS IBM Solution. You need to engage the Internal GTS BigFix Support.
There is an internal wiki where you can get all documentation, again it’s just visible for IBMers.
Just for the record URT (or .mef files extraction) is now replaced with ‘GUIDEXT’, same objetive, better capabilities is what the GTS section of IBM say.
