I’m testing v10 WebUI on Win2019 with a local MSSQL and I noticed after I start the BES WebUI service, it can take 30+ minutes before node.exe starts running to make the HTTP interface available.
Is that normal?
Just a heads up. This issue has been resolved in WebUI 10.0.4
Sun, 05 Sep 2021 22:09:57 +0000 -- WebUI service version 10.0.2.52 starting
Sun, 05 Sep 2021 22:09:57 +0000 -- [WebUI] Begin adjusting File Ownership and Security Settings for D:\Program Files (x86)\BigFix Enterprise\BES WebUI
Sun, 05 Sep 2021 22:22:56 +0000 -- [WebUI] Finished adjusting File Ownership and Security Settings.
Sun, 05 Sep 2021 22:22:56 +0000 -- OpenSSL Initialized (Non-FIPS Mode)
Sun, 05 Sep 2021 22:22:56 +0000 -- Using OpenSSL crypto library libBEScrypto64 - OpenSSL 1.0.2u 20 Dec 2019
Sun, 05 Sep 2021 22:22:56 +0000 -- [WebUI] Stopping WebUI service app
Sun, 05 Sep 2021 22:23:38 +0000 -- [WebUI] Starting WebUI service app
Sun, 05 Sep 2021 22:23:39 +0000 -- [WebUI] process started
Wed, 08 Sep 2021 17:26:47 +0000 -- WebUI service version 10.0.4.32 starting
Wed, 08 Sep 2021 17:26:47 +0000 -- OpenSSL Initialized (Non-FIPS Mode)
Wed, 08 Sep 2021 17:26:47 +0000 -- Using OpenSSL crypto library libBEScrypto64 - OpenSSL 1.0.2y 16 Feb 2021
Wed, 08 Sep 2021 17:26:48 +0000 -- [WebUI] Stopping WebUI service app
Wed, 08 Sep 2021 17:27:11 +0000 -- [WebUI] Starting WebUI service app
Wed, 08 Sep 2021 17:27:12 +0000 -- [WebUI] process started
Yup, that was my note I just added to https://bigfix-ideas.hcltechsw.com/ideas/BFP-I-123
However, where is the note from HCL saying this was included in 10.0.4?
I ran across this while still on 10.0.2. Upgraded to 10.0.4 and the issue was resolved.
However, I think it was addressed in the 10.0.3 update: https://support.bigfix.com/bes/changes/fullchangelist-100.txt (Issue BFP-19025 - DA KB0085253)
noap, its still unresolved !!! we have infra of 200K endpoints & WebUI taking up to 30 min from initialization to actual login page.
it might be not visible in smaller infra but WebUI does take lots of time, dont go with below statement its just mean WebUI is up & started initialization process, also below statement doesn’t guarantee that you will be seeing WebUI login page.
Actually I think the slow startup was resolved in 10.0.3 so if you’re seeing a 30-minute startup there may be an issue in your environment.
Check the service-wrapper.log to be sure your WebUI actually upgraded.
We are already on with HCL Dev team against case ID # CS0256781 HCL is trying different store procedure but 20-30 min delay always there
