Is anyone else having issues with WebReports lately? It seems some Windows Update has caused problems. From Windows 10, I can log in, choose "“Reports” and it’s fine. But I can’t open a report. It times out every time. If I access it from the Bigfix server itself there are no problems. One of my Windows 7 devices won’t work the other will. It’s like there’s some update to IE that is breaking it.
Web reports has generally worked better for me in Chrome, you might try it instead.
Eh, don’t like Chrome. It did work in Edge just fine. That’s why I’m thinking it’s a Windows Update that’s affecting it. I can RDP to the server and run it there with no problems, so WebReports itself is OK.
