hi,
I have 2 webreport server , I created one baseline 3 days back, which is only showing on one webreport server.
Web report server is showing last report time and action details.
How to sync it forcefully without restarting webreport server ?
hi,
I would suggest opening a case with HCL Support for this particular request. There is likely much more information that will be needed here to determine what might be causing this.
When you look under Administration --> Datasource Settings in Web Reports, do you see any errors under the View Errors field?
