i manually upgraded from BES 6.0.21 to BES 7.01 (i use a remote DB) and i cannot login to my web reports.
i am getting this message:
BESReporting database is too old to use with this version of WebReports. Please upgrade your BESReporting database or configure the LocalBESReportingServer DSN to a valid database.
any idea how i can upgrade the web reports database?
Contacting support would be good, probably the LocalBESReportingServer DSN was reset to point to the local computer instead of the remote SQL database. LocalBESReportingServer should go to the BESReporting database as well.
I ran the “InitializeBESReportsDB.exe BESReporting LocalBESReportingServer …” command and now our Web Reports are blown out; I don’t see anything on our Web Reports. Any ideas?
