Web Reporting Outstanding Fixlet Limitation
(imported topic written by Sogorman)
Hi there,
I’m having trouble displaying all applicable fixlets in a report. It seems to be capped at 1000 entries
I’ve changed the ‘
var diplayedRelevantFixlets = 1000;’ value in the fixlet_compliance.js.file on our Bigfix server to 5000 but after rebooting, I am still only seeing 1000 displayed. When I export to Excel, it only exports 1000 values. Is there anything else I can do to get around this problem?
Regards,
Steve
(imported comment written by liuhoting)
This is a known issue, and it’s this way for performance and usability reasons.
There’s a workaround where you can click on “Printable Version” where all results will then be stored in one document.
(imported comment written by Sogorman)
Thanks for the reply. I’m still being limited to 1000 entries when I click on the Printable Version option. I can break the report down into segments and combine them at the end. Its a little annoying!
Actually, couldn’t you just use the excel connector to do this?
https://www.ibm.com/developerworks/community/wikis/home?lang=en#!/wiki/Tivoli%20Endpoint%20Manager/page/Excel%20Connector
