system
1
(imported topic written by Marty23)
Hi;
I quess I have two questions.
does it matter if I use the wiathidden or runhidden command if I’m doing a DOS copy of a file. I don’t really think so but wanted to ask.
my action is working and I was wondering where to place the waithidden?
(Working Action) DOS xcopy C:\DIR\Filename \Server\share
Should it be
DOS waithidden c:\dir\Filename \Server\share
OR
waithidden DOS c:\dir\Filename \Server\Share
system
2
Marty,
The waithidden and the DOS commands cannot be combined on the same line.
waithidden will launch an executable or batch/cmd script and try to hide the console window.
dos will open a console window and run whatever command follows without trying to had the console window.
If you are trying to hide the black box, try writing your command to a batch file and running that:
appendfile xcopy C:\DIR\Filename \Server\share
delete cp.bat
move __appendfile cp.bat
waithidden cp.bat
-Jesse
system
3
(imported comment written by Marty23)
OK, then does that mean I can run this?
waithidden xcopy “C:\Documents and Settings\Iscr*.*” /S/H \ServerName\ShareName\
system
4
Hi Guys;
Never mind, I answered my own question!!
Marty
