Virtual Machine RAM CPU Info (VMWare)
Hello
I know out of the box BigFix brings back the amount of RAM that has been allocated to a virtual machine, but can it also bring back the amount of RAM that is currently being utilized by the virtual machine? For example, a RedHat box is allocated 16GB of RAM but it is only using 8.5. Not sure if this could be done in relevance or using the cloud solution.
What about the CPU, Allocated vs Utilized. I know you can see this info in vSphere for example, so I am hoping there is a way to do it either through relevance of the VMWare api in the cloud solution
Plenty of options here (although the search term ‘ram’ brings back some results we don’t want)
https://developer.bigfix.com/relevance/search/?query=ram
Search for ‘cpu’ is fairly precise though
https://developer.bigfix.com/relevance/search/?query=cpu
