Using regex to find filename?
(imported topic written by atxrobbie)
I’m having trouble using regex to find a filename. I need to check to see if a file exists, but i only know a regex pattern for the filename and not the filename itself. is this something that is possible to do?
thanks,
Robbie
(imported comment written by jgolembi)
atxrobbie,
This is completely do-able. I am not to skilled in the regular expression area, but maybe if you give me the expression I might be able to mock something up for you.
I would highly recommend that you download
this help file
and review the regular expression sections.
Also I would recommend that you get the
QNA fixlet debugger
  • invaluable when trying to get just the right answer to come back.
A few more helpful links:
http://support.bigfix.com
  • support search site for BigFix
Bigfix Documentation
  • Here you can find guides on Web reports, the Console, etc.
Fixlet authoring Wiki
Hopefully this all makes sense.
-John G
Try something like:
Q: names of files of folder "C:\QNA 7.2.5.22"
A: eval.exe
A: libBEScrypto_1_0_0_1.dll
A: PSAPI.DLL
A: qna.exe
A: RelevanceDebugger.exe
Q: exists matches (regex "^libBES*") of names of files of folder "C:\QNA 7.2.5.22"
A: True
I will leave it to you to craft the actual regular expression. :slight_smile:
Here are many more examples of using regex in relevance:
http://bigfix.me/cdb/search/relevance/regex
