Hi All.
I’m attempting to compare a list of existing file versions to a list of “unapproved” versions.
My Set query runs perfectly with an existing string:
q: exists elements of intersection of (set of (“5.2.3.0”;“5.3.14.0”;“5.3.8.0”); set of (“5.3.17.0”;“5.3.16.0”;“5.3.15.0”;“5.3.14.0”;“5.3.13.0”;“5.3.12.0”;“5.3.11.0”;“5.3.10.0”;“5.3.9.0”;“5.3.8.0”;“5.3.7.0”;“5.3.6.0”;“5.3.5.0”;“5.3.4.0”;“5.3.3.0”;“5.3.2.0”;“5.3.1.0”;“5.3.0.0”;“5.2.19.0”;“5.2.18.0”;“5.2.17.0”;“5.2.16.0”;“5.2.15.0”;“5.2.14.0”;“5.2.13.0”;“5.2.12.0”;“5.2.11.0”;“5.2.10.0”;“5.2.9.0”;“5.2.8.0”;".0";“5.2.7.0”;“5.2.6.0”;“5.2.5.0”;“5.2.4.0”;“5.2.3.0”;“5.2.2.0”;“5.2.1.0”;“5.2.0.0”))
A: True
T: 0.342 ms
I: singular boolean
When I attempt to substitute relevance that generates that first string, I get a FALSE answer (paths redacted):
q: ("%22" & (concatenation “%22;%22” of it of (((names of files whose (name of it as string as lowercase starts with “xxxxxx” AND name of it as string as lowercase ends with “.xxx”) of folders of folders “xxx\xxx\xxx\xxx\xxx” of folders of folder “C:\temp\test\users”) as version) as string)) & “%22”)
A: “5.2.3.0”;“5.3.14.0”;"5.3.8.0"
T: 16.587 ms
I: singular string
q: elements of (set of("%22" & (concatenation “%22;%22” of it of (((names of files whose (name of it as string as lowercase starts with “xxxxxx” AND name of it as string as lowercase ends with “.xxx”) of folders of folders “xxx\xxx\xxx\xxx\xxx” of folders of folder “C:\temp\test\users”) as version) as string)) & “%22”))
T: 13.104 ms
I: plural string
q: exists elements of intersection of ((set of ( ("%22" & (concatenation “%22;%22” of it of (((names of files whose (name of it as string as lowercase starts with “xxxxxx” AND name of it as string as lowercase ends with “.xxx”) of folders of folders “xxx\xxx\xxx\xxx\xxx” of folders of folder “C:\temp\test\users”) as version) as string)) & “%22”)) ); set of (“5.3.17.0”;“5.3.16.0”;“5.3.15.0”;“5.3.14.0”;“5.3.13.0”;“5.3.12.0”;“5.3.11.0”;“5.3.10.0”;“5.3.9.0”;“5.3.8.0”;“5.3.7.0”;“5.3.6.0”;“5.3.5.0”;“5.3.4.0”;“5.3.3.0”;“5.3.2.0”;“5.3.1.0”;“5.3.0.0”;“5.2.19.0”;“5.2.18.0”;“5.2.17.0”;“5.2.16.0”;“5.2.15.0”;“5.2.14.0”;“5.2.13.0”;“5.2.12.0”;“5.2.11.0”;“5.2.10.0”;“5.2.9.0”;“5.2.8.0”;".0";“5.2.7.0”;“5.2.6.0”;“5.2.5.0”;“5.2.4.0”;“5.2.3.0”;“5.2.2.0”;“5.2.1.0”;“5.2.0.0”))
A: False
T: 12.406 ms
I: singular boolean
What could I be doing wrong? I’ve tried many iterations of quotes, no quotes, as string, etc.
Thanks in advance.
Jim
