Is it possible to use BigFix to pull firmware versions from HP Servers?
Are these X86 or other types of servers?
And which OS’s (or OS Families) are you wanting the information from?
- Windows
- *NIX
There is a property BIOS that at least for most of my Windows computers returns a Date.
Q: BIOS as string
A: 01/14/13
T: 0.054 ms
The computer I run the Console on (and tested the above statement on) was manufactured in 04/2013 according to the sticker on the bottom, so that date seems about right.
On my Linux/Unix boxes, there is no BIOS object to inspect but something might be available through another object.
On my Mac, it returns the following …
Q: BIOS as string
A: MM71.88Z.0230.B00.1802091122
T: 45273
Not sure how to decode that string, but the last 10 digits appear to be a date (02/09/2018 1122). Might be able to Google to find how to decode that.
These results were with BES Client Versions > 9.5.1, but I believe the BIOS object has been there for a while.
These are X86 Windows servers.
I’m doing that with the dmi family of inspectors, should be able to post something shortly.
HP’s are a pain in particular because they don’t properly represent version numbers. “J20” is not a version!
Thanks very much all
This should help, depending on your needs…
q: vendors of bios_informations of dmi
A: Hewlett-Packard
T: 0.165 ms
I: plural string
q: manufacturer of system_information of dmi
A: Hewlett-Packard
T: 0.169 ms
I: singular string
q: family of system_information of dmi
A: 103C_53335X G=D
T: 0.164 ms
I: singular string
q: product_names of system_informations of dmi
A: HP Z420 Workstation
T: 0.170 ms
I: plural string
q: bios_versions of bios_informations of dmi
A: J61 v03.92
T: 0.167 ms
I: plural string
q: (system_bios_major_release of it as string & "." & system_bios_minor_release of it as string) of bios_informations of dmi
A: 3.92
T: 0.247 ms
I: plural string
q: bios_release_dates of bios_informations of dmi
A: 02/09/2018
T: 0.164 ms
I: plural string
// I wanted a sortable version
q: (parenthesized part 3 of it & "_" & parenthesized part 1 of it & "_" & parenthesized part 2 of it) of matches(regex("([[:digit:]]{2})/([[:digit:]]{2})/([[:digit:]]{4})")) of bios_release_dates of bios_informations of dmi
A: 2018_02_09
T: 0.610 ms
I: plural string
q: serial_number of system_information of dmi
A: 2UA3291DD1
T: 0.264 ms
I: singular string
q: sku_number of system_information of dmi
A: LJ449AV
T: 0.305 ms
I: singular string
Thanks very much. I am new to BigFix and not sure what to do with this info.
See https://www.ibm.com/support/knowledgecenter/en/SS63NW_9.5.0/com.ibm.bigfix.doc/Platform/Console/c_creating_analyses.html for instructions on creating an Analysis. Each of the queries I listed should be separate Properties in the analysis. Since they don’t change frequently, you should set “Evaluate Every:” to something like one week. Take the “Q:” of the front of my queries, the “Q:” is just a special term in the Fixlet Debugger - you never include that when working in the Console.
Once the Analysis is activated, you can read the results in the Results tab of the analysis; in the Details pane of any computer; or add the property as a Column on any computer view.
I tried Q:BIOS as string on windows server it’s returning date.
Can you please let me know the query to check the Firmware version.
Pay attention to the post from @JasonWalker. He includes WMI and DMI queries that will return additional information about the BIOS.
