Upgrade to 9.2.5 Login Problem
Hi, In BFI, I ran the fixlet to action the new upgrade to 9.2.5 but upon login, get the following error:
Suggestions?
Check tema.log for errors
Got a few of these in tema.log:
Have you tried to restart the service?
yes, that did not work either
can you send me entire tema.log file michal.paluch(at)pl.ibm.com
Sure, I can do that to see if you find anything that might indicate what happened. I eventually just uninstalled BFI, deleted the test temadb and started the install process over. I am able to log in now, but am curious as to what caused the issue. Thanks!
Most likely some sort of database connection configuration problem, cured by a re-install. Michal, if you can for sure link the TEMA.log error to a definitive reason, please post back. Thanks.
I need to take a look into tema.log to have a chance to uinderstand what might have caused it, if I find something, I will post it here.
http://www-01.ibm.com/support/docview.wss?uid=swg21992043
Thank you for the help, Michal. Should this ever occur again, I will try this solution. I appreciate you looking into it.
