Product:
BigFix Compliance
Title: Update: Improvements to Automated Scheduling and Centralized Reporting for RBI Compliance and SCAP 1.3 Wizard
This update includes important fixes and improvements to the RBI Compliance Report and the RBI Scheduler, focusing on data accuracy, usability, and improved diagnostics.
Resolved a defect in the Import SCAP 1.3 Content Wizard
Details:
- RBI Compliance Report
Fixed OS Filter Issue (BSU-18477)
Resolved a defect where OS-based filtering returned incorrect or incomplete results. The OS filter now accurately reflects devices across all operating systems. -
Added “N/A” for Empty Severity Values
Empty cells in the Severity column are now automatically marked as N/A to maintain consistency, readability, and reduce confusion in analysis.
- RBI Scheduler
- Improved Error Handling for Better Debugging
Improved error messages and exception tracking in the scheduler to make troubleshooting easier.
- Fix for SCAP Content Import Failure(BSU-18447)
Resolved a defect in the Import SCAP 1.3 Content Wizard where the wizard failed to process DISA SCAP 1.3 datastream XML files if the file path contained spaces or was incorrectly prefixed with file://.
Improvements included in this update:
File paths with spaces are now correctly quoted and handled by the wizard.
Automatic removal of erroneous file:// prefixes.
Improved logging for better visibility into main.exe execution, import progress, and diagnostic output.
These fixes ensure successful import of SCAP 1.3 content for Windows 11, RHEL 9, and other DISA-provided benchmarks.
Published Sites:
SCM Reporting, version 164
Actions to take:
To subscribe to the above site, you can use the License Overview Dashboard to enable and gather the site. Note that you must be entitled to the BigFix Compliance product, and you must be using BigFix version 9.5 and later.
Gather the indicated SCM Reporting site version.
Installation Instructions
If the RBI Scheduler is already installed:
Run Update RBI Scheduler (Fixlet ID #2003) to upgrade to the latest version. -
If the RBI Scheduler is not installed:
Run Install RBI Scheduler (Fixlet ID #2001) to install it.
To access RBI Compliance Dashboard
Go to the BigFix Web Reports.
Open the RBI Compliance from the Report list.
Wait for initial data synchronization to complete.
More information:
To know more about the BigFix Compliance: Support for RBI , please see the following resource:
BigFix Forum:
https://forum.bigfix.com/c/release-announcements/compliance -
RBI Compliance User Guide:
https://help.hcl-software.com/bigfix/11.0/compliance/Compliance/RBI_intro.html
