bd54
July 7, 2023, 5:11pm
1
Hello I an running into an issue where the unzipping command is the action script is not working…it seemed to work in the past:
Copy zip onto box (this command works fine):
copy “\x\x\x\x\file.zip” “C:\test\file.zip”
unzip file:
wait Powershell Expand-Archive -Path “C:\test\file.zip” -DestinationPath “C:\test”
The fixlet completes, but the file is not unzipped. I know there is an issue with zips over 2gbs but this is little over a gig, so shouldn’t be an issue.
Is there an alternative way to unzip this?
trn
July 8, 2023, 10:22am
2
I concocted this a while back.
// vvv PASTE INTO OTHER ACTIONS vvv
// << UNZIP USING POWERSHELL
// Disable wow64 redirection on x64 OSes
action uses wow64 redirection {not x64 of operating system}
parameter "theArchive" = "REPLACE"
parameter "theDest" = "REPLACE" // FOLDER NAME OF EXPANDED ARCHIVE
parameter "theTemp" = "{value of variable "TEMP" of environment}"
move __Download\{parameter "theArchive"} "{parameter "theTemp"}\{parameter "theArchive"}"
// CREATEFILE
delete __createfile
createfile until END_OF_FILE
Expand-Archive -Path "{parameter "theTemp"}\{parameter "theArchive"}" -DestinationPath "{parameter "theTemp"}"
END_OF_FILE
delete unzip.ps1
move __createfile unzip.ps1
waithidden { pathname of file ((it as string) of value "Path" of key "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\PowerShell\1\ShellIds\Microsoft.PowerShell" of native registry) } -ExecutionPolicy Bypass -File unzip.ps1
// REENABLE WOW64 REDIRECTION
action uses wow64 redirection {x64 of operating system}
// >> UNZIP USING POWERSHELL
// << CLEANUP
wait cmd /c del /q /s /f "{parameter "theTemp"}\{parameter "theArchive"}"
wait cmd /c rmdir /s /q "{parameter "theTemp"}\{parameter "theDest"}"
// >> CLEANUP
// ^^^ PASTE INTO OTHER ACTIONS ^^^
