[Unofficial Project] Introducing Client Relevance Studio - A Modern QnA IDE (Prototype)
Client Relevance Studio — Modern BigFix Relevance IDE (Unofficial Prototype)
Hey everyone,
I’ve been working on an unofficial, personal side project to make writing, testing, and managing BigFix relevance a bit smoother. I'm calling it Client Relevance Studio (currently available for Windows only).
This is currently a prototype in active development, but I’ve reached a point where I thought it would be useful to share it with the community. It’s essentially a standalone graphical IDE that acts as a modern wrapper around the standard BigFix qna.exe evaluation engine — with additional tooling, libraries, and now AI-assisted relevance generation.
I am actively planning to expand the built-in relevance library, inspector awareness, and AI capabilities over time.
I’ve attached the .exe below for anyone who wants to try it.
:warning: IMPORTANT DISCLAIMERS (Please Read Before Downloading) :warning:
  • Unofficial Prototype: This is a strictly independent, personal project still undergoing active improvements. It is not an official HCL product and comes with no official support.
  • Not Signed/Published: The attached executable is compiled for testing and is not digitally signed. Your web browser or local antivirus (like Windows Defender) will likely flag it as an unrecognized app.
  • DO NOT USE IN PRODUCTION: Please do not run this on a Production server, a relay, or any critical business endpoint. It is designed for use in a lab, sandbox, or dedicated testing environment only.
  • App Signing: Code and application signing is in progress. Once, that is completed I will update it the same forum post and then, it will ready and safe to use in production.
:sparkles: Features & Functionalities
:puzzle_piece: Modern Relevance IDE
  • Clean syntax-aware editor (CodeMirror)
  • Line numbers & bracket matching
  • Active line highlighting
  • Multi-line editing support
  • Fast local evaluation
:books: Built-In Relevance Library
Preloaded categorized queries including:
  • OS
  • Hardware
  • Registry
  • Network
  • Services
  • Filesystem
  • Security
  • Users
  • Installed Applications
This library will continue to expand over time.
:star: Custom Bookmarks
Save frequently used relevance snippets for quick reuse.
:nine_o_clock: Persistent Query History
  • Stores last 100 queries
  • Retained for 10 days
  • Auto-restores after restart
:high_voltage: Batch Evaluation
Evaluate multiple lines at once.
Shortcut:
Ctrl + Enter
:magnifying_glass_tilted_right: Search & Filter
Search across:
  • Built-in library
  • bookmarks
  • history
  • evaluation results
:outbox_tray: Rich Export Options
Export evaluation results to:
  • CSV
  • JSON
  • HTML
  • PDF
  • XML
  • TXT
:locked_with_key: Local Execution Only
No cloud dependency.
Queries are passed securely to local qna.exe.
:robot: NEW: SmartSense AI Assistant
Client Relevance Studio now includes AI-assisted relevance generation designed specifically for BigFix.
Capabilities include:
Generate Relevance
Describe what you want in plain English:
"Get BitLocker status for system drive"
AI generates valid BigFix relevance.
Explain Relevance
Paste existing relevance and get explanation.
Optimize Relevance
AI can simplify or improve performance.
Inspector-Aware Generation
AI uses built-in inspector knowledge to avoid hallucinations.
Context Modes
AI understands:
  • Client Relevance
  • Session Relevance
  • Action Script context
Local Knowledge Retrieval (RAG)
AI uses embedded:
  • relevance library
  • inspector definitions
  • common BigFix patterns
This helps produce accurate BigFix-safe output.
Multi-Provider AI Support
Supports:
  • Groq
  • Gemini
  • Anthropic
(Provider configurable)
:inbox_tray: Download & Running Steps (Windows Only)
Download the attached .exe from:
https://github.com/nikhil1067/BigFix-Ops-Studio/releases/tag/BigFix-Ops-Studio-v1.0.0
And install it on your system.
If BigFix Client is Installed
You're ready to go — Studio automatically locates:
qna.exe
If BigFix Client is NOT installed
Download standalone QnA utility and place:
qna.exe
in same folder as:
BigFix Ops Studio.exe
Then run:
Right click → Run as Administrator
(Admin recommended so qna.exe can access registry/security metrics)
Since this is an ongoing project, I’d love to hear your feedback to help shape future updates. Let me know what you guys think! If you encounter any weird edge cases, bugs, or have specific suggestions for default queries to add to the growing library, please drop a comment below.
Looks like that the repo is not public
The repository is public now. You should be able to access it.
Hey everyone,
We have organized a LinkedIn webinar to showcase the initial version, highlighting the features and capabilities of this tool.
Please use the link below to register:
https://www.linkedin.com/events/introducingclientrelevancestudi7442553856414216192/
im not able to access it https://github.com/nikhil1067/BigFix-Ops-Studio/releases/tag/BigFix-Ops-Studio-v1.0.0
im seeing that nikhil1067 doesn’t have any public repositories yet
Hi @nikhilraj_1 ,
I was hoping to play with App before release but seems the github link is not available/private
Until he will return it to Public - this is the Forked version - GitHub - orbiton21/BigFix-Advanced-QNA-IDE: A modern, standalone IDE and graphical wrapper for the HCL BigFix QnA engine. Features batch evaluation, syntax highlighting, and a built-in relevance library. (Windows Only) · GitHub
We are currently fixing a few security vulnerabilities. Once this is completed, we will publish it again for use. We will also provide an update in the same post. Please stay with us — we will keep you posted.
Any update here on the security fixes?
:rocket: The wait is over! BigFix Ops Studio v1.0.0 is now available.
First and foremost, thank you for your patience, and support throughout this journey.
Many of you may remember BigFix Ops Studio as an unofficial community utility created to simplify day-to-day BigFix operations. We are excited to share that this is no longer the case.
:tada: BigFix Ops Studio is now an official open-source project released by HCL.
The goal of BigFix Ops Studio is to provide administrators and operators with a modern and efficient experience for working with BigFix relevance and operational workflows.
Included in v1.0.0
  • Client Relevance Studio — Query endpoint properties locally and validate relevance expressions quickly and efficiently.
Planned for future releases
  • Session Relevance Studio — Session relevance queries for the BigFix Console.
  • Action Script Studio — Create, test, and manage BigFix Action Script snippets.
You can access BigFix Ops Studio using the following URL:
:link: Access URL: Release BigFix Ops Studio v1.0.0 · HCL-TECH-SOFTWARE/OpsStudio · GitHub
We look forward to your feedback, ideas, and contributions as we continue to expand the platform and add new capabilities for the BigFix community.
