system
1
hi,
i want to write a custom setting on my BESClient
setting “HDDDrivelockState” = “{now}” on “{now}” for client
I get following error:
STATUS: Running action…
Command failed (Unimplemented command ‘setting’.) setting “HDDDrivelockState” = “{now}” on “{now}” for client
Evaluation failed!
Earlier this always works fine.
Where is the problem now??
Please for help.
Andi
leewei
2
Some ActionScript commands cannot be run from the Fixlet Debugger.
Just run it from an actual Fixlet and it will work correctly.
system
3
I test it again and i get this error:
Fixlet Action:
setting “HDDDrivelockState”="{now}" on “{now}” for client
Message Console:
Failed setting “HDDDrivelockState”="{now}" on “{now}” for client
Logfile on Client:
Command failed (Error writing setting to registry) setting “HDDDrivelockState”=“Mon, 17 Sep 2012 07:48:49 +0200” on “Mon, 17 Sep 2012 07:48:49 +0200” for client (fixlet 48795)
Thanks Andi
system
4
hi Lee Wei.
do you have an idea, why I get these error?
Thanks Andi
leewei
5
Looks like spaces before and after the equal sign “=” causes problems.
Here is an export of a Task that works for me.
If this does not work for you, at least we know that it is environmental rather than the code.
Lee Wei
system
6
hi,
i test your fixlet, but I get the same error.
Andi
leewei
7
Looks like the problem is not with the ActionScript statement, but something with the endpoint.
You should probably try this on different endpoints. Maybe call tech support to help verify the environment in terms of component versions etc.
