UNC / Mapped drive path query fails from console
(imported topic written by JamesN91)
(if property “ProviderName” of it as string contains “=” then (substring after “=” of (property “Name” of it as string) & substring after “=” of (property “ProviderName” of it as string)) else nothing) of select objects(“Name,ProviderName from win32_LogicalDisk”)of WMI
In local debugger this relevance works perfect. I get back a list of mapped drives with path.
When I run through console across network I get errors in the web reports and no results.
I have a feeling it is because the debugger is running as my local user and the console runs it as system which has no drives mapped to it.
Is there a way around this issue so I can get a list of mapped drives from the bes client?
(imported comment written by rd6591)
My understanding is that your feeling is correct. With the added complication that mapped drives are tied to each user - i.e. you’ll get different results depending on which user you look at.
To check the current logged on user, this might work, based on the current user sticky in this forum (I haven’t tested it):
(name of it & “:” & value “RemotePath” of it as string) of keys of (keys(“Network”) of (key whose ((it = name of current user as lowercase OR it starts with name of current user as lowercase & “@” ) of (it as string as lowercase) of value “Logon User Name” of key “Software\Microsoft\Windows\CurrentVersion\Explorer” of it) of key “HKEY_USERS” of registry) )
You might want to extract the information from all users that have logged on rather than the current one…?
(imported comment written by JamesN91)
Reg keys in the above rel were not accurate per my enviroment.
I searched the reg for a combinations of information dealing with the mapped drive / path and did not find what I need.
How is xp storing the mapped drive info per user profile if not in reg?
HKEY_CURRENT_USER/Network seems only to store persistent connections. If you manually map a drive on the command line with NET USE, you should see drives appear under this key.
Not sure how you would access non-persistent mappings. The only relevant key I can find is HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\MountPoints2
Could you run a VBS script with RunAsCurrentUser to get the information into a file and access it from there?
Something like this which writes the results in c:\drives.txt :
download http://0.0.0.0:52311/Uploads/9e1216a456aa8f6d162feef0fe52794bd32d7f85/RunAsCurrentUserexe.tmp
continue if {(size of it = 67002 AND sha1 of it = “9e1216a456aa8f6d162feef0fe52794bd32d7f85”) of file “RunAsCurrentUserexe.tmp” of folder “__Download”}
extract RunAsCurrentUserexe.tmp
delete __appendfile
delete c:\netuse.vbs
appendfile Option Explicit
appendfile Dim network, drives, i, fso, f
appendfile Set fso = CreateObject(“Scripting.FileSystemObject”)
appendfile Set network = CreateObject(“WScript.Network”)
appendfile set f = fso.CreateTextFile(“c:\drives.txt”,True)
appendfile Set drives = network.EnumNetworkDrives
appendfile for i = 0 To drives.Count - 1 Step 2
appendfile f.WriteLine drives.Item(i) & " " & drives.Item(i+1)
appendfile next
appendfile f.Close
copy __appendfile c:\netuse.vbs
delete __appendfile
wait __Download\RunAsCurrentUser.exe --w {pathname of (system folder)}\cscript c:\netuse.vbs
rd
No info under HKEY_CURRENT_USER/Network.
I see the key you referenced, but need to think on how to make that work.
We are in need of this data now and were wondering if there is any way to get this to work?
(imported comment written by amitkumsingh91)
Please try this for Mapped Drive Path through BigFix for Win 7 or Win XP
if Exists(value “RemotePath” of it as string) of keys of (keys(“Network”) of Keys of key “HKEY_USERS” of registry) then (name of it & “:” & value “RemotePath” of it as string) of keys of (keys(“Network”) of Keys of key “HKEY_USERS” of registry) else “Shared Drive Not Found”
@amitkumsingh - Thank you. This seems to pull back drives mapped manually or via a batch file, but for some reason not via vbscript. It’s a great start for us, so thanks again!
