UEFI / Legacy ( Relevance Need)
Dear Team,
How to find out Which boot method is enable UEFI / Legacy through analysis ( Relevance needed ).
Hi.
C3 Inventory contains an analysis for this: https://bigfix.me/analysis/details/2998369 (or on Github https://github.com/strawgate/C3-Inventory/blob/master/Analyses/UEFI%20-%20Windows.bes)
Bill
thanks, that’s helpful.
I forgot where I found this from, but someone else had shared pulling this status from setupact.log - I think I prefer that WMI method though, and secure boot is a helpful addition.
(following text of last ", " of it | it) of concatenations ", " of following texts of firsts "Detected boot environment: " of lines containing "Detected boot environment: " of files "setupact.log" of folders "Panther" of windows folders
I actually ran into my first batch of computers that are classic BIOS but GPT partition style. This was really puzzling, I’ve never seen a machine that wasn’t MBR if it was classic BIOS. I couldn’t figure out why our crappy encryption solution couldn’t install for a little bit (current version only supports BIOS/MBR).
Yeah, it’s definitely not perfect – The issue with this:
Is that setupact.log can be HUGE on some systems. We were seeing it take upwards of an hour to scan on some machines.
Dear @strawgate
The following C3 Inventory analysis code shown the result like True / False like below
Q: exists Selects "* from Win32_DiskPartition Where Type = 'GPT: System'" of wmi
A: False
Q: if (value "UEFISecureBootEnabled" of keys "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SecureBoot\State" of native registry = 1) then "Enabled" else "Disabled"
can you modify this one result look like below
Legacy = Enable
UEFI = Disable
Regards
Vicky
The specific property is called, “UEFI - Windows” so true/false makes more sense here. If it’s true the system is UEFI if it’s false the system is Legacy.
You can achieve what you’re looking for with a simple if then else statement…
if (exists Selects "* from Win32_DiskPartition Where Type = 'GPT: System'" of wmi) then ("whatever") else ("whateverelse")
the simpliest way is to read environnement variables:
(it as lowercase = “legacy”) of value of variable “FIRMWARE_TYPE” of environment
(it as lowercase = “uefi”) of value of variable “FIRMWARE_TYPE” of environment
Because an EFI partition could exist without booting it in UEFI mode…
