Hi All,
I was wondering if anyone has seen this issue and might have an idea on a solution.
When I create a report in the “Explore Data” I can view the data and go back and forth on the pages (see next 50). It all seems good until I save the report and then try to move from page to page. When I do that, I get the message “TypeError: Cannot read property ‘getId’ of undefined”.
The stack trace shows:
Stack:
at WR.ComputerPropertiesDataTable.method (https://bigfix.servername.com:8083/JavaScript/yui/build/datatable/datatable-min.js?modified=3590688976:16:2754)
at YAHOO.util.Chain.run (https://bigfix.servername.com:8083/JavaScript/yui/build/datatable/datatable-min.js?modified=3590688976:7:467)
at WR.ComputerPropertiesDataTable._runRenderChain (https://bigfix.servername.com:8083/JavaScript/yui/build/datatable/datatable-min.js?modified=3590688976:16:2125)
at WR.ComputerPropertiesDataTable.render (https://bigfix.servername.com:8083/JavaScript/yui/build/datatable/datatable-min.js?modified=3590688976:16:3605)
at WR.ComputerPropertiesDataTable.onDataReturnSetRows (https://bigfix.servername.com:8083/JavaScript/yui/build/datatable/datatable-min.js?modified=3590688976:25:3723)
at WR.ComputerPropertiesDataTable.success (https://bigfix.servername.com:8083/JavaScript/DataTable/DataTable-min.js?modified=3590688975:1:6428)
at Function.issueCallback (https://bigfix.servername.com:8083/JavaScript/yui/build/datasource/datasource-min.js?modified=3590688976:7:2026)
at WR.DataSource.handleResponse (https://bigfix.servername.com:8083/JavaScript/yui/build/datasource/datasource-min.js?modified=3590688976:8:3998)
at WR.DataSource._xhrSuccess (https://bigfix.servername.com:8083/JavaScript/yui/build/datasource/datasource-min.js?modified=3590688976:10:5708)
at Object.handleTransactionResponse (https://bigfix.servername.com:8083/JavaScript/yui/build/connection/connection-min.js?modified=3590688976:8:4333)
I have enabled debug logging and there does not seem to be any information there.
If I export to CSV, all data is displayed. It just seems to be when I try to go to the next page in Web Reports.
Any ideas?
