Need assistance I’m trying to install MS Project in GUI mode but unable to install it using below command, whenever installing using runascurretuser.exe getting dual setup.exe instance running in taskbar.
I notice you did not include a source path in your xml. Are you pushing all of the install files directly to each client? Seems like that would be a lot of unnecessary workload. I’ve used a similar config to install 365, but I used software distribution to upload the setup.exe and xml file, while the xml file pointed to a server with the rest of the install files
@MMosley, Files already placed in client machines I only want to execute the command and show installation progress, so that if installation interrupt/fail then user can get some error code/msg.
The user may not have administrative rights to install software or there’s something wrong with the method you’re using. I’d follow @MMosley’s advice above and try the SWD Dashboard to deploy.
@JasonWalker,We are placing files well advance in user machine and only want to execute the command via BigFix. Also setup.exe already whitelisted and non-admin user can execute it but still it is not working via BigFix.
Besides that, we tried to run the commands using below action scripts but again no luck same issue happened (two instance of Setup.exe running together)
//Another method tried in VB Scrip
We tried with RunAsCurrentUser.exe utility but no luck (facing issue of two instance of Setup.exe running together) although we checked the script and tried manually it is working as expected only issue is with BigFix.
Have you tested manually running the script as the same user account that’s logged on when running it through BigFix? Maybe something wrong with that user’s profile?
The ActionScript looks correct, and if the user has admin rights and read permission to all of the files & directories involved, I’d have to troubleshoot this as an Office problem, not necessarily a BigFix issue.
I would also at least try the “Manage Software Distribution” method that others on this thread have used successfully.
You can also use steps with current user settings like in your 1st execution action.
However as @JasonWalker mentioned your steps seems correct but something is not working from os prospective, if your setup is working locally without any special arrangements it should be working without any issue from BigFix.
I have seen many cases where some parameters is required as pre set which sometime missing while running it from BigFix is not looked properly. There could be other conflicts related to access on the machine, pre req of any which might not come in light till now, could be that machine have some os issues etc.
You could also try using cmd.exe /k just for troubleshooting purposes. As you would be running this as the user that should keep the CMD prompt that was spawned by the client visible on screen so you can see if there are any anomalies with the syntax of the command line. Sometimes I’ve had to use double double quotes for long filenames though I can’t see your use case would need that, eg
