I want to return the last value on the line ( ie the “cbc”
Using the following command does not work… I’m thinking the “,” between that ibmhmc8,ibmhmc10 is causing issue
Q: tuple string item 3 of concatenation ", " of substrings separated by “:” of line whose ( it contains “Location” ) of file “/opt/sni/unix/etc/mojo.out” as trimmed string
following texts of lasts "Location : " of lines whose ( it contains "Location : " ) of files “c:\test.txt” as trimmed string
The reason is that it contains “Location” does not actually check for the “:” character, while "Location : " does. You should not split a string based upon a character you have not asserted exists within it first for error checking reasons. I feel it is better to use the entire token that precedes the data of interest symmetrically in both the “it contains” and “lasts” statement. I also changed the singulars into plurals which removes some of the need for error checking. A singular relevance statement implies that it must return exactly one result, no more no less, while a singular statement implies 0 or more results. I recommend plural for reporting and existence purposes. For relevance substitution, it depends - sometimes singular would be better for deterministic reasons… in actionscript it is often better to fail with errors than to continue in an unexpected state.
