I’m trying to get web reports, and eventually, the REST API to leverage a trusted cert so we can communicate over https effectively. I followed the instructions here to get a CSR(https://help.hcltechsw.com/bigfix/10.0/platform/Platform/Config/SSL_config_main_steps.html) and received a primary cert from my company’s internal CA.
I then followed the instructions here (https://help.hcltechsw.com/bigfix/10.0/platform/Platform/Config/private_key_certificate_format.html) to combine my primary cert, root cert and intermediate cert into a .pem file that BigFix can read. Before combining them, I used openssl to convert the .der files to x509 pem files per the instructions.
I then updated the computer settings on my root server per this webpage (https://help.hcltechsw.com/bigfix/10.0/platform/Platform/Web_Reports/c_web_reports_https_registry_set.html) and that broke webreports.
Based on the log, webreports doesn’t like the certificate. Is there any way to diagnose this?
Tue, 23 Mar 2021 18:52:13 -0500 – 5724 – Initializing Web Reports version 10.0.2.52
Tue, 23 Mar 2021 18:52:13 -0500 – 5724 – Using cURL library - 7.73.0-DEV
Tue, 23 Mar 2021 18:52:13 -0500 – 5724 – OpenSSL Initialized (Non-FIPS Mode)
Tue, 23 Mar 2021 18:52:13 -0500 – 5724 – Using OpenSSL crypto library libBEScrypto64 - OpenSSL 1.0.2u 20 Dec 2019
Tue, 23 Mar 2021 18:52:13 -0500 – 5724 – FXF character set is windows-1252
Tue, 23 Mar 2021 18:52:13 -0500 – 5724 – TLS Cipher List: HIGH:!ADH:!AECDH:!kDH:!kECDH:!PSK:!SRP
Tue, 23 Mar 2021 18:52:13 -0500 – 5724 – Successful ODBC call returned:
[Microsoft][SQL Server Native Client 11.0][SQL Server]Changed database context to ‘BESReporting’. (01000: 5,701)
[Microsoft][SQL Server Native Client 11.0][SQL Server]Changed language setting to us_english. (01000: 5,703)
Tue, 23 Mar 2021 18:52:13 -0500 – 5724 – Begin web reports scheduling thread…
Tue, 23 Mar 2021 18:52:13 -0500 – 5724 – Begin web reports background thread…
Tue, 23 Mar 2021 18:52:13 -0500 – 5724 – Connecting to datasource: BIGFIX
Tue, 23 Mar 2021 18:52:13 -0500 – 5724 – XML parsing error: unable to open primary document entity ‘BESDomain_3_0.xsd’ Line 0, Character 0
Tue, 23 Mar 2021 18:52:14 -0500 – 1140 – Starting background thread for BIGFIX (2299764259)
Tue, 23 Mar 2021 18:52:14 -0500 – 1140 – Beginning WebReportsSession::RefreshStores (full refresh)…
Tue, 23 Mar 2021 18:52:14 -0500 – 1140 – ThreadedTaskManager::Queue(): 0 tasks in queue
Tue, 23 Mar 2021 18:52:14 -0500 – 1140 – Queued bg task struct UserRoleRefresh::Refresh
Tue, 23 Mar 2021 18:52:14 -0500 – 1140 – ThreadedTaskManager::Queue(): 1 tasks in queue
Tue, 23 Mar 2021 18:52:14 -0500 – 1140 – Queued bg task struct UserRefresh::Refresh
Tue, 23 Mar 2021 18:52:14 -0500 – 1140 – ThreadedTaskManager::Queue(): 2 tasks in queue
Tue, 23 Mar 2021 18:52:14 -0500 – 1140 – Queued bg task class SiteRefresh::Task
Tue, 23 Mar 2021 18:52:14 -0500 – 1140 – ThreadedTaskManager::Queue(): 3 tasks in queue
Tue, 23 Mar 2021 18:52:14 -0500 – 1140 – Queued bg task class ActionSiteStoreRefresh::Task
Tue, 23 Mar 2021 18:52:14 -0500 – 1140 – ThreadedTaskManager::Queue(): 4 tasks in queue
Tue, 23 Mar 2021 18:52:14 -0500 – 1140 – Queued bg task class ActionRefresh::Task
Tue, 23 Mar 2021 18:52:14 -0500 – 1140 – ThreadedTaskManager::Queue(): 5 tasks in queue
Tue, 23 Mar 2021 18:52:14 -0500 – 1140 – Queued bg task class FixletVisibilityRefresh::Task
Tue, 23 Mar 2021 18:52:14 -0500 – 1140 – ThreadedTaskManager::Queue(): 6 tasks in queue
Tue, 23 Mar 2021 18:52:14 -0500 – 1140 – Queued bg task struct RegistrationServerRefresh
Tue, 23 Mar 2021 18:52:14 -0500 – Background (5492) – RunOneBackgroundTask: 7 tasks in queue
Tue, 23 Mar 2021 18:52:14 -0500 – 5724 – Opening socket with IP address: ::
Tue, 23 Mar 2021 18:52:14 -0500 – 5724 – Attempting to load certificate and private key file assuming PEM encoding/formatting…
Tue, 23 Mar 2021 18:52:14 -0500 – 5724 – Attempting to load certificate and private key file assuming ASN1 / DER encoding…
Tue, 23 Mar 2021 18:52:14 -0500 – 5724 – Cannot create the SSL context. Private key must be stored along with the certificate or SSLPrivateKeyFilePath must be set to a proper value.
Tue, 23 Mar 2021 18:52:14 -0500 – 5724 – HTTPServer error: wrong tag; nested asn1 error; ASN1 lib (class OpenSSLError)
Tue, 23 Mar 2021 18:52:14 -0500 – HTTPRedirect Server Thread (5692) – Opening socket with IP address: ::
Tue, 23 Mar 2021 18:52:14 -0500 – Background (5492) – ForegroundTaskQueue::Receive(): 0 tasks in queue
Tue, 23 Mar 2021 18:52:14 -0500 – Background (5492) – Queued fg task struct UserRoleRefresh::Complete
Tue, 23 Mar 2021 18:52:14 -0500 – Background (5492) – RunOneBackgroundTask: 6 tasks in queue
Tue, 23 Mar 2021 18:52:14 -0500 – 1140 – Queued bg task class UnmanagedAssetRefresh::Task
Tue, 23 Mar 2021 18:52:14 -0500 – 1140 – Queued bg task class LicenseUpdateRefreshTask
Tue, 23 Mar 2021 18:52:14 -0500 – 1140 – ThreadedTaskManager::Queue(): 7 tasks in queue
Tue, 23 Mar 2021 18:52:14 -0500 – 1140 – Queued bg task class DashboardDataRefresh::RefreshTask
Tue, 23 Mar 2021 18:52:14 -0500 – 1140 – ThreadedTaskManager::Queue(): 8 tasks in queue
Tue, 23 Mar 2021 18:52:14 -0500 – 1140 – Queued bg task class ComputerRefresh::Task
Tue, 23 Mar 2021 18:52:14 -0500 – 1140 – ThreadedTaskManager::Queue(): 9 tasks in queue
Tue, 23 Mar 2021 18:52:14 -0500 – 1140 – Queued bg task class FixletResultRefresh::Task
Tue, 23 Mar 2021 18:52:14 -0500 – 1140 – ThreadedTaskManager::Queue(): 10 tasks in queue
Tue, 23 Mar 2021 18:52:14 -0500 – 1140 – Queued bg task class PropertyResultRefresh::RefreshTask
Tue, 23 Mar 2021 18:52:14 -0500 – 1140 – ThreadedTaskManager::Queue(): 11 tasks in queue
Tue, 23 Mar 2021 18:52:14 -0500 – 1140 – Queued bg task class ActionResultRefresh::Task
Tue, 23 Mar 2021 18:52:14 -0500 – 1140 – ThreadedTaskManager::Queue(): 12 tasks in queue
Tue, 23 Mar 2021 18:52:14 -0500 – 1140 – Queued bg task class CommentStoreRefreshTask
Tue, 23 Mar 2021 18:52:14 -0500 – 1140 – ThreadedTaskManager::Queue(): 13 tasks in queue
Tue, 23 Mar 2021 18:52:14 -0500 – 1140 – Queued bg task class HistoricalComputerRefresh::Task
Tue, 23 Mar 2021 18:52:14 -0500 – 1140 – ThreadedTaskManager::Queue(): 14 tasks in queue
Tue, 23 Mar 2021 18:52:14 -0500 – 1140 – Queued bg task class HistoricalFixletRefresh::Task
Tue, 23 Mar 2021 18:52:14 -0500 – 1140 – ThreadedTaskManager::Queue(): 15 tasks in queue
Tue, 23 Mar 2021 18:52:14 -0500 – 1140 – Queued bg task struct anonymous namespace'::Refresh Tue, 23 Mar 2021 18:52:14 -0500 -- 1140 -- ThreadedTaskManager::Queue(): 16 tasks in queue Tue, 23 Mar 2021 18:52:14 -0500 -- 1140 -- Queued bg task class FireSignalTask Tue, 23 Mar 2021 18:52:14 -0500 -- 1140 -- Exiting WebReportsSession::RefreshStores... Tue, 23 Mar 2021 18:52:14 -0500 -- Background (5492) -- ForegroundTaskQueue::Receive(): 1 tasks in queue Tue, 23 Mar 2021 18:52:14 -0500 -- Background (5492) -- Queued fg task struct UserRefresh::Complete Tue, 23 Mar 2021 18:52:14 -0500 -- Background (5492) -- RunOneBackgroundTask: 17 tasks in queue Tue, 23 Mar 2021 18:52:14 -0500 -- 1140 -- servicing foreground task for: BIGFIX Tue, 23 Mar 2021 18:52:14 -0500 -- 1140 -- RunOneForegroundTask(): 2 tasks in queue Tue, 23 Mar 2021 18:52:14 -0500 -- 1140 -- MEMORY USAGE: 111.695/134213464.000/4152.258/131415848.000; peak 111.695/2048.000/4152.258/2048.000 [commit/free/reserve/maxFreeBlock, in MB] Tue, 23 Mar 2021 18:52:14 -0500 -- 1140 -- servicing foreground task for: BIGFIX Tue, 23 Mar 2021 18:52:14 -0500 -- 1140 -- RunOneForegroundTask(): 1 tasks in queue Tue, 23 Mar 2021 18:52:14 -0500 -- 1140 -- XML parsing error: unable to open primary document entity 'BESDomain_3_0.xsd' Line 0, Character 0 Tue, 23 Mar 2021 18:52:14 -0500 -- 1140 -- XML parsing error: unable to open primary document entity 'BESDomain_3_0.xsd' Line 0, Character 0 Tue, 23 Mar 2021 18:52:14 -0500 -- 1140 -- MEMORY USAGE: 111.715/134213464.000/4152.223/131415848.000; peak 111.715/2048.000/4152.258/2048.000 [commit/free/reserve/maxFreeBlock, in MB] Tue, 23 Mar 2021 18:52:14 -0500 -- Background (5492) -- SiteRefresh() - Getting fixlets and files of site BES Support Tue, 23 Mar 2021 18:52:14 -0500 -- Background (5492) -- GetExternalFixletsAndFiles() - Decompressing the site content in the temp dir.. Tue, 23 Mar 2021 18:52:16 -0500 -- Background (5492) -- VerifyExternalSite() - verifying site BES Support Tue, 23 Mar 2021 18:52:16 -0500 -- Background (5492) -- VerifyExternalSite() - VerifySubscription SubscribeSMIME Tue, 23 Mar 2021 18:52:16 -0500 -- Background (5492) -- VerifyExternalSite() - VerifySubscription UnsubscribeSMIME Tue, 23 Mar 2021 18:52:28 -0500 -- 1140 -- refreshing BIGFIX... Tue, 23 Mar 2021 18:52:28 -0500 -- 1140 -- Beginning WebReportsSession::RefreshStores... Tue, 23 Mar 2021 18:52:28 -0500 -- 1140 -- ThreadedTaskManager::Queue(): 16 tasks in queue Tue, 23 Mar 2021 18:52:28 -0500 -- 1140 -- Queued bg task struct UserRoleRefresh::Refresh Tue, 23 Mar 2021 18:52:28 -0500 -- 1140 -- ThreadedTaskManager::Queue(): 17 tasks in queue Tue, 23 Mar 2021 18:52:28 -0500 -- 1140 -- Queued bg task struct UserRefresh::Refresh Tue, 23 Mar 2021 18:52:28 -0500 -- 1140 -- ThreadedTaskManager::Queue(): discarding duplicate task class SiteRefresh::Task Tue, 23 Mar 2021 18:52:28 -0500 -- 1140 -- ThreadedTaskManager::Queue(): discarding duplicate task class ActionSiteStoreRefresh::Task Tue, 23 Mar 2021 18:52:28 -0500 -- 1140 -- ThreadedTaskManager::Queue(): discarding duplicate task class ActionRefresh::Task Tue, 23 Mar 2021 18:52:28 -0500 -- 1140 -- ThreadedTaskManager::Queue(): discarding duplicate task class FixletVisibilityRefresh::Task Tue, 23 Mar 2021 18:52:28 -0500 -- 1140 -- ThreadedTaskManager::Queue(): discarding duplicate task struct RegistrationServerRefresh Tue, 23 Mar 2021 18:52:28 -0500 -- 1140 -- ThreadedTaskManager::Queue(): discarding duplicate task class DashboardDataRefresh::RefreshTask Tue, 23 Mar 2021 18:52:28 -0500 -- 1140 -- ThreadedTaskManager::Queue(): discarding duplicate task class ComputerRefresh::Task Tue, 23 Mar 2021 18:52:28 -0500 -- 1140 -- ThreadedTaskManager::Queue(): discarding duplicate task class FixletResultRefresh::Task Tue, 23 Mar 2021 18:52:28 -0500 -- 1140 -- ThreadedTaskManager::Queue(): discarding duplicate task class PropertyResultRefresh::RefreshTask Tue, 23 Mar 2021 18:52:28 -0500 -- 1140 -- ThreadedTaskManager::Queue(): discarding duplicate task class ActionResultRefresh::Task Tue, 23 Mar 2021 18:52:28 -0500 -- 1140 -- ThreadedTaskManager::Queue(): discarding duplicate task class CommentStoreRefreshTask Tue, 23 Mar 2021 18:52:28 -0500 -- 1140 -- ThreadedTaskManager::Queue(): discarding duplicate task class HistoricalComputerRefresh::Task Tue, 23 Mar 2021 18:52:28 -0500 -- 1140 -- ThreadedTaskManager::Queue(): discarding duplicate task class HistoricalFixletRefresh::Task Tue, 23 Mar 2021 18:52:28 -0500 -- 1140 -- ThreadedTaskManager::Queue(): discarding duplicate task struct
anonymous namespace’::Refresh
Tue, 23 Mar 2021 18:52:28 -0500 – 1140 – ThreadedTaskManager::Queue(): discarding duplicate task class FireSignalTask
Tue, 23 Mar 2021 18:52:28 -0500 – 1140 – Exiting WebReportsSession::RefreshStores…
Tue, 23 Mar 2021 18:52:28 -0500 – 1140 – Connection error while updating AGGREGATEDBY: class PEMReadX509Failed
Tue, 23 Mar 2021 18:52:34 -0500 – Background (5492) – VerifyExternalSite() - each file of the site has been verified successfully.
Tue, 23 Mar 2021 18:52:36 -0500 – Background (5492) – SiteRefresh() - Getting fixlets and files of site Enterprise Security
Tue, 23 Mar 2021 18:52:36 -0500 – Background (5492) – GetExternalFixletsAndFiles() - Decompressing the site content in the temp dir…
Tue, 23 Mar 2021 18:52:41 -0500 – Background (5492) – VerifyExternalSite() - verifying site Enterprise Security
Tue, 23 Mar 2021 18:52:41 -0500 – Background (5492) – VerifyExternalSite() - VerifySubscription SubscribeSMIME
Tue, 23 Mar 2021 18:52:41 -0500 – Background (5492) – VerifyExternalSite() - VerifySubscription UnsubscribeSMIME
Tue, 23 Mar 2021 18:52:43 -0500 – 1140 – refreshing BIGFIX…
Tue, 23 Mar 2021 18:52:43 -0500 – 1140 – Beginning WebReportsSession::RefreshStores…
Tue, 23 Mar 2021 18:52:43 -0500 – 1140 – ThreadedTaskManager::Queue(): discarding duplicate task struct UserRoleRefresh::Refresh
Tue, 23 Mar 2021 18:52:43 -0500 – 1140 – ThreadedTaskManager::Queue(): discarding duplicate task struct UserRefresh::Refresh
Tue, 23 Mar 2021 18:52:43 -0500 – 1140 – ThreadedTaskManager::Queue(): discarding duplicate task class SiteRefresh::Task
Tue, 23 Mar 2021 18:52:43 -0500 – 1140 – ThreadedTaskManager::Queue(): discarding duplicate task class ActionSiteStoreRefresh::Task
Tue, 23 Mar 2021 18:52:43 -0500 – 1140 – ThreadedTaskManager::Queue(): discarding duplicate task class ActionRefresh::Task
Tue, 23 Mar 2021 18:52:43 -0500 – 1140 – ThreadedTaskManager::Queue(): discarding duplicate task class FixletVisibilityRefresh::Task
Tue, 23 Mar 2021 18:52:43 -0500 – 1140 – ThreadedTaskManager::Queue(): discarding duplicate task struct RegistrationServerRefresh
Tue, 23 Mar 2021 18:52:43 -0500 – 1140 – ThreadedTaskManager::Queue(): discarding duplicate task class DashboardDataRefresh::RefreshTask
Tue, 23 Mar 2021 18:52:43 -0500 – 1140 – ThreadedTaskManager::Queue(): discarding duplicate task class ComputerRefresh::Task
Tue, 23 Mar 2021 18:52:43 -0500 – 1140 – ThreadedTaskManager::Queue(): discarding duplicate task class FixletResultRefresh::Task
Tue, 23 Mar 2021 18:52:43 -0500 – 1140 – ThreadedTaskManager::Queue(): discarding duplicate task class PropertyResultRefresh::RefreshTask
Tue, 23 Mar 2021 18:52:43 -0500 – 1140 – ThreadedTaskManager::Queue(): discarding duplicate task class ActionResultRefresh::Task
Tue, 23 Mar 2021 18:52:43 -0500 – 1140 – ThreadedTaskManager::Queue(): discarding duplicate task class CommentStoreRefreshTask
Tue, 23 Mar 2021 18:52:43 -0500 – 1140 – ThreadedTaskManager::Queue(): discarding duplicate task class HistoricalComputerRefresh::Task
Tue, 23 Mar 2021 18:52:43 -0500 – 1140 – ThreadedTaskManager::Queue(): discarding duplicate task class HistoricalFixletRefresh::Task
Tue, 23 Mar 2021 18:52:43 -0500 – 1140 – ThreadedTaskManager::Queue(): discarding duplicate task struct `anonymous namespace’::Refresh
Tue, 23 Mar 2021 18:52:43 -0500 – 1140 – ThreadedTaskManager::Queue(): discarding duplicate task class FireSignalTask
Tue, 23 Mar 2021 18:52:43 -0500 – 1140 – Exiting WebReportsSession::RefreshStores…
Tue, 23 Mar 2021 18:52:43 -0500 – 1140 – Connection error while updating AGGREGATEDBY: class PEMReadX509Failed
