We’re trying to run a python script on Linux servers with no luck. I’ve tried packaging the script and running it in a BigFix task, also by creating a file then running it that way. But neither runs using BigFix. Although that same file runs successfully locally. So that tells me it’s the way we’re running it via BigFix.
The python script is a downloaded onboarding script for Microsoft Defender Advanced Threat Protection. The command used to run the script is listed below.
Again, the same file that is downloaded using BigFix runs successfully when ran locally.
Has anyone run a python script in Linux? What am I doing wrong?
What messages do you get in the client log when the action runs? At first glance, I think that ‘python’ might not be in the PATH for the BESClient service, so you might try supplying the full path to python i.e. /bin/python or whatever your installed path is.
Hi Jason, I usually get completed exit code 1 . Also, python is in /usr/bin so I 've used the full path as well. Each time, I leave the file behind so that I can verify the file locally and it runs with a simple “python MicrosoftDefenderATPOnboardingLinuxServer.py” command that completes successfully.
That should run with a login shell (processes things like .login that may supply more environment variables), and redirects the output and error messages to /tmp/output.txt. reading the output file may give more clues if python or the script itself are presenting error messages.
I don’t see anything on the Microsoft site about that. It basically says to copy the file down locally and run the command I’m using, but that might be in play here.
Note
To run this command, you must have python or python3 installed on the device depending on the distro and version. If needed, see Step-by-step Instructions for Installing Python on Linux.
If you’re running RHEL 8.x or Ubuntu 20.04 or higher, you will need to use python3.
Here’s the link on how to deploy MS Defender for Endpoint on Linux Manually. We’re able to get the mde_installer.sh script pushed with no issues. It’s this python script giving us grief.
I ran your command and it came back with exit code 127 and the server is still not onboarded. In other words, not healthy or licensed.
Ah, my mistake. You mentioned earlier that python was at /use/bin/python, but ai mistyped that as /usr/sbin/python. Try changing that path to python.
Also, verify that /usr/bin/python is python version 3, since the Microsoft script says it requires that. I’d expect that /usr/bin/python might be python v2 and there may be a /usr/bin/python3 to run (or install) instead.
Jason, after running your command with the correct path (Wait /bin/sh --login -c “/usr/bin/python /tmp/MicrosoftDefenderATPOnboardingLinuxServer.py > /tmp/output.txt 2>&1”), I received the output below.
“sudo: sorry, you must have a tty to run sudo
Generating /etc/opt/microsoft/mdatp/mdatp_onboard.json …
Command ‘sudo mkdir -p ‘/etc/opt/microsoft/mdatp’’ returned non-zero exit status 1”
After reading up on tty or teletypewriter and understanding it, I checked our sudoers file, I realized that the following line was present.
“Defaults requiretty”
I changed that to…
“Defaults !requiretty”
I’ve tested my task on a few servers which installs Microsoft Defender for Endpoint on Linux, and onboarding script all in one command (command below), runs successfully now. Before only the mde_installer.sh portion would complete, not the onboarding python script.
Because I was able to run numerous tasks & fixlets (installs, config changes, patches) on these servers, I was perplexed with this python file. I wasn’t familiar with “TTY Requirement” so I can’t thank you enough for pointing me to the root cause.
I owe you a beer or two for sure!
Thank you Jason!
I guess that internally their python script was explicitly trying to execute ‘sudo’… that shouldn’t be necessary when running via BigFix because we run with root privilege already, but their script must assume that sudo is needed.
That seems a bit janky, i.e. I would not appreciate a script silently sudo’ing something for me, better to let the script fail and let me know I need to sudo before running the script as a whole, but I guess it’s not shocking MS would do it that way.
You know, I opened the file searching and thinking, do curly brackets come in to play here? But then I thought, nah…can’t be within a prefetched downloaded file. But I didn’t think to search for sudo.
Sure enough. Here are the contents of that file.
" Line 34: print(‘Re-running as sudo (you may be required to enter sudo’‘s password)’)
Line 35: os.execvp(‘sudo’, [‘sudo’, ‘python’] + sys.argv) # final version
Line 39: cmd = “sudo mkdir -p ‘%s’” % (os.path.dirname(destfile))
I learned a few things today that I’m going keep in my back pocket for another time. It’s good to know BigFix has guys like you to help out with issues like these.
Hey @Splendiz , here’s the BES file, I hope it helps. If not, let me know and I’ll try to help out as much as possible. Although, I can’t remember what I did last week, let alone two years ago. LOL
Thanks, @JoeG finally got the time to take care of this.
Works like a charm with your script. I simply uploaded the mde_installer.sh and MicrosoftDefenderATPOnboardingLinuxServer.py from Microsoft to Bigfix and re-created your task.
ActionScript
//delete files if they exists
delete /tmp/MicrosoftDefenderATPOnboardingLinuxServer.py
delete /tmp/mde_installer.sh
//Execute shell and onboarding script
wait /bin/sh -c “/tmp/mde_installer.sh --install --channel prod --onboard /tmp/MicrosoftDefenderATPOnboardingLinuxServer.py --tag GROUP MY-TAG --min_req -y”
//delete files after
delete “/tmp/MicrosoftDefenderATPOnboardingLinuxServer.py”
delete "/tmp/mde_installer.sh
and relevance
Relevance
(version of client >= “6.0.0.0”) AND ((exists true whose (if true then (exists (operating system) whose (it as string as lowercase contains “linux” as lowercase)) else false)) AND (exists true whose (if true then (not exists running service “mdatp”) else false)))
In our case, I didn’t have to touch the sudoers file because “Defaults requiretty” wasn’t part of it in the first place, so no modifications needed there.
@JoeG What changes you made for python script to run, i have similar deployment in my customer environment and getting the error code as 12 21 23 24 31
Yes, sure, we gave help on this, and solved it over a year ago. I think if you're having some issue you'll need to create a topic of your own and describe what's going on for you.
Sorry for the delay, was OOO. My issue was that our sudoers file on our linux boxes had the line “Defaults requiretty” in it. This forces sudo to be run within a logged-in terminal session. So I couldn’t run that script remotely from BigFix. I changed that line to “Defaults !requiretty” which disables that requirement. After that, I was able to successfully run my python scripts via BigFix. I hope that helps as I remember this issue which had me stummped until Jason suggested I try the command below. The output of that command is what pointed me to tty which I was unfamiliar with at the time. Just change the script name and path to yours to see the output and hopefully help you determine what it’s complaining about.
