Apologies for the beginners question (again ).
How I can troubleshoot “not reported” items in the Analysis?
I have a simple analysis - looking for 2 items, both items work fine from qna but show “not reported” on the Results tab of the Analysis. I can see “Successful Synchronization” with my site (site141) in the log.
My only thought - time spend on executing the request in qna looks high for a simple query. Is it indeed high?
Thank you,
Aleksandr
Simple analysis is asking for:
A) number of line containing “CUSTOM” of file "/var/log/messages"
B) version of package “tda-check-bigfix-agent” of rpm as string
Both seem to be simple and work in qna as expetced:
[root@h0002039 ~]# /opt/BESClient/bin/qna
Default masthead location, using /etc/opt/BESClient/actionsite.afxm
Q: number of line containing “CUSTOM” of file "/var/log/messages"
A: 0
T: 5101062
Q: version of package “tda-check-bigfix-agent” of rpm as string
A: 0.4-1
T: 11136151
Q: ^C
[root@h0002039 ~]#
[root@h0002039 ~]# grep -B2 -A1 site141 /var/opt/BESClient/__BESData/__Global/Logs/20190416.log | tail -14
Successful Synchronization with site ‘CustomSite_UNIX-2fLinux_Production_Support’ (version 2169726,43) - 'http://bigfix.associatesys.local:52311/cgi-bin/bfgather.exe/CustomSite_UNIX-2fLinux_Production_Support’
At 07:47:20 -0500 -
Successful Synchronization with site ‘opsite141’ (version 2174238,43) - 'http://bigfix.associatesys.local:52311/cgi-bin/bfgather.exe/opsite141’
At 07:51:20 -0500 -
Successful Synchronization with site ‘opsite13’ (version 1738238,43) - 'http://bigfix.associatesys.local:52311/cgi-bin/bfgather.exe/opsite13’
Successful Synchronization with site ‘opsite138’ (version 1738238,43) - 'http://bigfix.associatesys.local:52311/cgi-bin/bfgather.exe/opsite138’
At 08:12:50 -0500 - opsite141 (http://bigfix.associatesys.local:52311/cgi-bin/bfgather.exe/opsite141)
Downloaded ‘http://PRDTXWPRISAS01.prod-am.ameritrade.com:52311/bfmirror/bfsites/manydirlists_101/__diffsite_4a27b918b953904bf4d7ba2d558a7e22c8fdd6a1_to_e72444f9e741178f10190c4fe5c88766407f3bd7’ as '__TempUpdateFilename’
Gather::SyncSiteByFile merging files - count: 2
At 08:12:50 -0500 -
Successful Synchronization with site ‘opsite141’ (version 2174886,43) - 'http://bigfix.associatesys.local:52311/cgi-bin/bfgather.exe/opsite141’
At 08:12:51 -0500 -
[root@h0002039 ~]#
