(imported topic written by JasonBigham91)
Only machine at entire location that will not install. Not sure how to proceed. Advice?
LOG:
c:\Program Files\BigFix Enterprise\BES Client__BESData__Global\Logs\20100226.log
ActionLogMessage: (action 1046 ) Non-Distributed - DownloadsAvailable
ActionLogMessage: (action 1046 ) starting action
At 21:34:49 -0800 - Trend Core Protection Module (http://sync.bigfix.com/cgi-bin/bfgather/trendcpm)
Command succeeded action parameter query “install_path” with description “Specify an installation path%0A%0AFor default installation path, leave blank” (fixlet 1046)
Command succeeded (evaluated true) continue if {(if (it = “”) then (true) else ((not exists matches (regular expression "
") of it) of ((parenthesized part 3 of matches (regular expression “^(\w+):(\)?(.*)$”) of it) as string) of (if (it starts with “%22” AND it ends with “%22”) then ((preceding text of position (length of it - 1) of it) of (following text of position 1 of it) of it) else (it)))) of ((parameter “install_path” of action) as string)} (fixlet 1046)
Command succeeded (evaluated true) continue if {(if (it = “”) then (exists it whose (type of it = “DRIVE_FIXED” AND free space of it >= 70010241024) of (drive of parent folder of client)) else (if (exists parenthesized part 2 of matches (regular expression “^(%22)?(\w):”) of it) then ((exists drive it whose (type of it = “DRIVE_FIXED” AND free space of it >= 70010241024)) of ((parenthesized part 2 of matches (regular expression “^(%22)?(\w):”) of it as string) & “:”)) else (false))) of ((parameter “install_path” of action) as string)} (fixlet 1046)
At 21:34:50 -0800 - Trend Core Protection Module (http://sync.bigfix.com/cgi-bin/bfgather/trendcpm)
Command succeeded delete “C:\WINDOWS\CPMInstallResult.log” (fixlet 1046)
At 21:34:59 -0800 - Trend Core Protection Module (http://sync.bigfix.com/cgi-bin/bfgather/trendcpm)
Command succeeded (Exit Code=0) waithidden “C:\Program Files\BigFix Enterprise\BES Client__BESData\Trend Core Protection Module__Download\TMCPMInstaller.exe” -i “C:\Program Files\Trend Micro” (fixlet 1046)
At 21:35:08 -0800 - Trend Core Protection Module (http://sync.bigfix.com/cgi-bin/bfgather/trendcpm)
Command failed (File not found) delete ondemand.ini (fixlet 1046)
Command failed (Relevance substitution failed) delete “{(value “Application Path” of keys “HKEY_LOCAL_MACHINE\SOFTWARE\TrendMicro\CPM” of registry as string)}\ondemand.ini” (fixlet 1046)
Command failed (Substitution failed while writing file) createfile until __DONE (fixlet 1046)
At 21:35:16 -0800 -
ActionLogMessage: (action 1046 ) ending action
At 21:36:22 -0800 -
Report posted successfully.
At 21:38:00 -0800 -
