Refer to Qualys id - 38628
Disable the use of TLSv1.0 protocol in favor of a cryptographically stronger protocol such as TLSv1.2.
The following openssl commands can be used to do a manual test:
openssl s_client -connect ip:port -tls1
If the test is successful, then the target support TLSv1
SSL/TLS use of weak RC4(Arcfour) cipher
Refer to Qyalys id 38601,
CVE-2013-2566, CVE-2015-2808
RC4 should not be used where possible. One reason that RC4(Arcfour) was still being used was BEAST and Lucky13 attacks against CBC mode ciphers in SSL and TLS. However, TLSv 1.2 or later address these issues.
QID 38657: Birthday attacks against TLS ciphers with 64bit block size vulnerability (Sweet32)
RELEVANCE:
1.exists operating system whose(name of it starts with "Win")
2.(NOT exists key "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SecurityProviders\SCHANNEL\Ciphers\Triple DES 168" of registry) OR (NOT exist value "Enabled" of key "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SecurityProviders\SCHANNEL\Ciphers\Triple DES 168" of native registry) OR (value "Enabled" of key "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SecurityProviders\SCHANNEL\Ciphers\Triple DES 168" of native registry as string != "0")
(NOT exists key "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SecurityProviders\SCHANNEL\Protocols\TLS 1.0" of registry) OR (NOT exists key "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SecurityProviders\SCHANNEL\Protocols\TLS 1.0\Server" of registry) OR (NOT exists value "Enabled" of key "HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\SecurityProviders\SCHANNEL\Protocols\TLS 1.0\Server" of native registry) OR (value "Enabled" of key "HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\SecurityProviders\SCHANNEL\Protocols\TLS 1.0\Server" of native registry as string != "0")
ACTION:
delete __appendfile
delete customedit.reg
appendfile Windows Registry Editor Version 5.00
appendfile
appendfile [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SecurityProviders\SCHANNEL\Protocols\TLS 1.0\Server]
appendfile "Enabled"=dword:00000000
move __appendfile customedit.reg
waithidden regedit /s "customedit.reg"
waithidden net stop TermService /y
waithidden net start TermService /y
QID 38601: SSL/TLS use of weak RC4 cipher
RELEVANCE:
2.(NOT exists key "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SecurityProviders\SCHANNEL\Ciphers" of registry) OR (NOT exists key "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SecurityProviders\SCHANNEL\Ciphers\DES 56/56" of registry) OR (NOT exists key "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SecurityProviders\SCHANNEL\Ciphers\NULL" of registry) OR (NOT exists key "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SecurityProviders\SCHANNEL\Ciphers\RC2 128/128" of registry) OR (NOT exists key "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SecurityProviders\SCHANNEL\Ciphers\RC2 40/128" of registry) OR (NOT exists key "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SecurityProviders\SCHANNEL\Ciphers\RC2 56/128" of registry) OR (NOT exists key "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SecurityProviders\SCHANNEL\Ciphers\RC4 128/128" of registry) OR (NOT exists key "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SecurityProviders\SCHANNEL\Ciphers\RC4 40/128" of registry) OR (NOT exists key "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SecurityProviders\SCHANNEL\Ciphers\RC4 56/128" of registry) OR (NOT exists key "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SecurityProviders\SCHANNEL\Ciphers\RC4 64/128" of registry) OR (NOT exists value "Enabled" of key "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SecurityProviders\SCHANNEL\Ciphers\DES 56/56" of native registry) OR (NOT exists value "Enabled" of key "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SecurityProviders\SCHANNEL\Ciphers\NULL" of native registry) OR (NOT exists value "Enabled" of key "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SecurityProviders\SCHANNEL\Ciphers\RC2 128/128" of native registry) OR (NOT exists value "Enabled" of key "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SecurityProviders\SCHANNEL\Ciphers\RC2 40/128" of native registry) OR (NOT exists value "Enabled" of key "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SecurityProviders\SCHANNEL\Ciphers\RC2 56/128" of native registry) OR (NOT exists value "Enabled" of key "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SecurityProviders\SCHANNEL\Ciphers\RC4 128/128" of native registry) OR (NOT exists value "Enabled" of key "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SecurityProviders\SCHANNEL\Ciphers\RC4 40/128" of native registry) OR (NOT exists value "Enabled" of key "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SecurityProviders\SCHANNEL\Ciphers\RC4 56/128" of native registry) OR (NOT exists value "Enabled" of key "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SecurityProviders\SCHANNEL\Ciphers\RC4 64/128" of native registry) OR (value "Enabled" of key "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SecurityProviders\SCHANNEL\Ciphers\DES 56/56" of native registry as string != "0") OR (value "Enabled" of key "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SecurityProviders\SCHANNEL\Ciphers\NULL" of native registry as string != "0") OR (value "Enabled" of key "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SecurityProviders\SCHANNEL\Ciphers\RC2 128/128" of native registry as string != "0") OR (value "Enabled" of key "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SecurityProviders\SCHANNEL\Ciphers\RC2 40/128" of native registry as string != "0") OR (value "Enabled" of key "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SecurityProviders\SCHANNEL\Ciphers\RC2 56/128" of native registry as string != "0") OR (value "Enabled" of key "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SecurityProviders\SCHANNEL\Ciphers\RC4 128/128" of native registry as string != "0") OR (value "Enabled" of key "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SecurityProviders\SCHANNEL\Ciphers\RC4 40/128" of native registry as string != "0") OR (value "Enabled" of key "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SecurityProviders\SCHANNEL\Ciphers\RC4 56/128" of native registry as string != "0") OR (value "Enabled" of key "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SecurityProviders\SCHANNEL\Ciphers\RC4 64/128" of native registry as string != "0")
I am looking to perform checks then changes to any server that has the registry values incorrect or enabled by default. I tried using the âBirthday attacks against TLS ciphers with 64bit block size vulnerability (Sweet32)â script but receive an relevance syntax error Line 1. I also receive errors on the second âActionâ. I donât know the action script language well enough to figure it oue.
Sorry Trn for the ignorance, but I understand smart quotes â â but do not know what you mean when you say dim quotes. If they are " " at this point so if I read this wright " " should be changed to something else. I have tried â '. moving around () etc⌠But obviously I donât understand.
