Need some help real quick from you more seasoned Big Fixers. I need a quick Task or Fixlet that will simply delete all files that end with .TMP located in the folder C:\Windows\Temp.
Very appreciative!
Sno
Very appreciative!
Sno
here you go -
delete __createfile
delete del.cmd
createfile until EOF
CD C:\Windows\Temp
del /s /q /f *.tmp
EOF
move __createfile del.cmd
wait cmd.exe /C del.cmd
Thanks for your help!
I am no CMD/PS scripter, try searching over internet you will find many solutions for that after that you can convert them into BigFix action script.
