This is harping back to another post back in nov 17 that was working for me but has again changed adding two further parameters… The Annoying thing is that it works perfectly in Fixlet Debugger but not in the fixlet.
appendfile {concatenation “%0d%0a” of (if (it contains case insensitive regex (parameter “TextToReplace1”)) then ((parameter “NewText1”)) else (if (it contains case insensitive regex (parameter “TextToReplace2”)) then ((parameter “NewText2”)) else it) ) of lines of file (parameter “FilePath”)}
Parameters have been defined. It iterates thought the file in question but changes nothing in the actual fixlet action… The fixlet debugger works perfectly.
The file is in a folder off C:\ProgramData
