TEM Patch Management for Oracle Enterprise Linux servers will be “comming soon”. Is there any published roadmap?
We installed the BESAgent-8.2.1175.0-rhe5.x86_64.rpm on the OEL server. Where can we configure the credentials for the Unbreakable Linux Network to populate the patch repository?
Please contact me, if you have any info about TEM Patch Management Client for Oracle Enterprise Linux.
From what I gather, OEL support is not yet included in the plan. You can submit a request for enhancement (RFE) in the RFE Community. The following link points to a page which has the request form:
IEM agents and solutions both run on and support the use of RHEL Linux.
(4,5,6). We do not create OEL patch content so our recommendation to
users is to ‘tweak’ RHEL fixlets to patch OEL directly using the RHEL
fixlets.
Posting again in the second thread: You would need to install agents on your OEL machines and you would need an Entitled Oracle Linux Account to use for downloading patches.
