Hello,
Just got the new MacBook Pro with 10.8.1 and installed the latest TEM client on it (8.2.1322.0). Client seems to check in according to logs, but always stops at the same place and never shows up in the console. Here’s a log from the machine (server name has been masked with xxx):
At 12:37:31 -0400 -
Starting client version 8.2.1322.0 built for OSX 10.60 i386
FIPS mode enabled by masthead.
At 12:37:32 -0400 -
Cryptographic module initialized successfully in FIPS mode.
Using crypto library libBEScrypto_1_0_0_1 - OpenSSL 0.9.8f-fips-dev xx XXXX xxxx
Restricted mode
Beginning Relay Select
At 12:37:33 -0400 -
RegisterOnce: Attempting to register with ‘http://xxx/cgi-bin/bfenterprise/clientregister.exe?RequestType=RegisterMe60&ClientVersion=8.2.1322.0&Body=3746575&SequenceNumber=11&MinRelayVersion=6.0.0.0&CanHandleMVPings=1&Root=http://xxx%3A443&AdapterInfo=20-c9-d0-49-04-2f_149.24.177.0%2F25_149.24.177.23_0&AdapterIpv6=20-c9-d0-49-04-2f^fe80%3A%3A22c9%3Ad0ff%3Afe49%3A42f%2F64_0’
Unrestricted mode
Configuring listener without wake-on-lan
Registration Server version 8.2.1312.0 , Relay version 8.2.1312.0
At 12:37:34 -0400 -
Entering service loop
SetupListener success: IPV4/6
At 12:38:41 -0400 - actionsite (‘http://xxx/cgi-bin/bfgather.exe/actionsite)
Download ‘‘http://xxx/bfmirror/bfsites/manydirlists_2/__fullsite_1c64b67ad8b2f571798063d431ad91a49d9ee1a1’ as ‘__TempUpdateFilename’
The last line is where it stops. I can open Safari and paste the URL and it will download what looks like an encrypted/encoded file without any issues. Any ideas on what may be causing it?
Thanks!
